This is the mounting location I have elected in an FE2. My pictures won't show any detail of the mounting bracket I made, but will show the location. I used a piece of aluminum strap that was about as wide as the base of the FT unit and bent it in a vise to make it fit my mounting points.
I opted for the FT to be off center just a bit because I am concerned the FT may interfere with interpreting my shift lights on the steering wheel. I have not powered the unit on yet, so I don't know how bright the thing is going to be. The other benefit of offsetting it is that I can adjust my left hand onto the upper portion of steering wheel and partially block my view of the FT if the thing is as bright as my rain light !!
I did have to use a die grinder and take a little of the fiberglass away from my shock cover. The air deflector is painted black and you can see where there is a little black paint on the shock cover itself. Where that black paint is under the air deflector has been removed to allow the wiring to run over the metal pipe and under the shock cover. The two connections that come into these ports are actually quite stiff. It may be possible to heat this stuff with a heat gun and gently convince it to bend in an area where needed. But, with my location, the wires can run straight from the back of FT and don't need a bend for a good distance.
There does appear to be a good bit of wiring with the unit. But, I wouldn't say it is completely ridiculous. The AIM FSW4 had some fairly long leads that I don't use and had to find a way to coil them up and out of the way. I am not that concerned with the amount of wiring on the FT.
I place my AIM GPS antenna under the shock cover and magnetically stuck to frame of car. I am gonna try and mount the GPS antenna for FT in the same area and hope it works through the fiberglass shock cover with no issue. I really don't want to have to hang this thing out in the wind somewhere. If it does have to be external. The antenna is probably going back next to where the master switch is. The FE2 side panels have a flat area there that I think will be a decent place to put it.
