    Liked: 97
    Default WTB, 91 to 97 Van Diemen rear wheels
    Hello, I could use 3 to 5 of the 91 through 97 FC rear wheels. I can trade late model Van Diemen wheels or buy them outright.
    They need to be straight!! I have enough bent ones around here already!
    Thanks for looking,
    Skip Weld
    Weldmotorsports gmail com
    Liked: 804
    have a one-off BBS if it suits your needs
    Liked: 97
    What is the back spacing?
    Skip
    Wilmington, Ohio
    Quote Originally Posted by Skip Weld View Post
    Thanks for looking,
    Skip Weld
    Skip, is there a particular brand you're looking for. Tecnos, OZ's, Dymag's?
    Liked: 804
    Skip
    hard to be precise with the tire in place, but looks like 5" (+/-)
    Liked: 97
    Quote Originally Posted by rg2 View Post
    The older 5 spoke OZ would be first choice but I will consider others if in a set of 4 I can then sell my front OZ wheels
    Skip
    Wilmington, Ohio
    Thanks for looking,
    Skip Weld
    Skip, Your message said you were looking for rear FC wheels. I have three 5 spoke OZ's for sale. Unfortunately, only one of the three is an 8 inch rear. The rear is a 2 1/4 center hole. 3 3/4 drive pin spacing. 1/2 or 13MM drive pin holes. 3 3/4 backspacing. straight and no corrosion. if you're interested the fronts are 2 1/4 center hole. 3 3/4 drive pin spacing. 1/2 or 13MM drive pin holes. 3 1/2 back spacing. Straight and no corrosion but obviously a narrower 6 inch wheel.
