    Member Mikej's Avatar
    Dallas
    Default Camber compensator for early AD
    Does anyone have a picture of a Early autodynamic camber compensator or Z bar setup. Thanks
    near Athens, GA
    Liked: 843
    Try contacting Dietmar at QuixoteRacing.com. He KNOWS about that ole zbar stuff
    BLS
    Lakeside
    Liked: 58
    Default Camber Compensator
    Camber Compensator can be found at JBugs.com, Appletree.com, or look up Empi Camber Compensator.
    Also, just Google: VW type 1 camber compensator and lots of pics will show up.
    As for the z bar, I do not have pics but from what I remember from my Mark 4 and Mark 5, there were two short tubes that the z bar went through. On these tubes, there was a tab welded at an angle and mounted to the bolts that held the shocks. Then the bar was bent. On the ends we used aluminum clamps- rectangular pieces that had a slit cut so the clamp could compress around the bar and a 3/8 hole held the struts for the bar. Because of the distance between the mounts, we found that a center support was needed .
    Hope that helps.
    And Steve, I am not THAT old!
    Dietmar
    fvraceri@cox.net
    www.quixoteracing.com
    Burr Ridge, Illinois
    Liked: 301
    Quote Originally Posted by Dietmar View Post
    Appletree.com
    Actually...it's appletreeauto.com
    Jus' helpin'.
    Glenn
