Results 1 to 11 of 11
    Placentia, CA
    Liked: 341
    Default Size of Class Weight Stickers
    I just want to make sure. While the size of the car number and the class designation are clearly defined in the GCR (8" with 1.5" stroke and 4" with 0.5" stroke respectively), it does not appear that there is a minimum size for the weight stickers. The only thing I can find is it must be " clearly legible to the scrutineers at the scales." (9.3.28(D)).
    I need to have stickers made up and before I send off my order, I want to make sure I have this correct. Oh, and if I print the class weight for FF at 1050, I can run that weight... right?
    Oh wait, found that part, "all cars shall display the correct minimum weight specified in the current GCR" Where is the fun in that?
    Eric Little
    Liked: 1262
    you didn't like the giant stickers handed out in fontana?
    Senior Member David Locke's Avatar
    Indiana
    Liked: 175
    Quote Originally Posted by Eric Little View Post
    Yes, the requirement is that they must be displayed "in a manner that is clearly legible to the scrutineers at the scales." Not an opinion as to what this means in terms of size, but mine are about 1 inch high and I haven't had anyone say they're too small (yet). YMMV.
    Contributing Member farrout's Avatar
    Sanibel, FL
    I also use a 1 inch height. That is easily legible for the tech folks sitting by the side of the scales.
    Craig Farr
    2006 Stohr WF1 P2
    FARROUT Racing
    Senior Member andyllc's Avatar
    Columbia, SC
    Liked: 201
    Are all cars/classes now required to have the weight displayed? I thought in the past it was only for classes where there were multiple min weights?
    Indiana
    Liked: 175
    Quote Originally Posted by andyllc View Post
    GCR 9.3.28.D: "Except for classes in which there is only 1 required minimum weight (i.e., ASR, FB, FC, FE, FF, FM, FS, FST, FV, SM5, SRF), all cars shall display the correct minimum weight specified in the current GCR in a manner that is clearly legible to the scrutineers at the scales."
    Santa Cruz, ca
    Liked: 183
    Quote Originally Posted by David Locke View Post
    (dec. 2016 GCR)
    GCR 9.1.1.20 weights
    Formula F
    Ford Cortina Engine: 1060 lbs.
    Ford Kent and Honda Fit Engines: 1110 lbs.
    so do we display minimum weights on the FF? Also, GCR 9.3.28.D requires restrictor size too.
    full wording from dec 2016 GCR:
    9.3.28.D Displaying Minimum Weight and Restrictor Size Type
    Except for classes in which there is only 1 required minimum weight (i.e., ASR, FB, FC, FE, FF, FM, FS, FST, FV, SM5, SRF), all cars shall display the correct minimum weight specified in the current GCR in a manner that is clearly legible to the scrutineers at the scales. Cars that are run in more than one class must display the correct minimum weight for each class so that it is clear which weight applies to each class. Any car required to run a restrictor must display the restrictor size and type in a manner that is clearly legible to the scrutineers. If the car also displays a minimum weight, it is recommended that the restrictor information be located near the displayed minimum weight.
    Indiana
    Liked: 175
    Quote Originally Posted by chrisw52 View Post
    GCR 9.1.1.20 weights [/b]
    Formula F
    The language indicates that if a class includes more than one minimum weight, then cars in that class must display their correct minimum weight. Looks like the parenthetical needs to updated to remove FF.
    Indiana
    Liked: 175
    I've put in a CRB letter to correct the parenthetical.
    Placentia, CA
    Liked: 341
    Nope! It was fine for me when I was a member of a different sanctioning body that did not require the class designation and the weight. But now that I am an official SCCA member (be affraid SCCA, be very affraid), I would like to make the class designation and the weight match the other stickers on the car.
    Thanks to everyone that has given input on this topic. I will order up some 1" class weight stickers and be ready to go. License application is about to go in the mail as well and I will see the SoPac racers in February at Buttonwillow.
    Eric Little
    Placentia, CA
    Liked: 341
    Okay, so in addition to my number, FF, and 1110, I now need a sticker that says "Driver" since that is my restrictor? Or do I need to measure the driver and is that height, weight, or both?
    Man this SCCA stuff can be confusing.
    See, I am saving money by running a Kent. I don't need to pay for stickers showing the restrictor size. So much for the Honda being more cost effective.
    Eric Little
