Does anyone have a picture of a Early autodynamic camber compensator or Z bar setup. Thanks
Try contacting Dietmar at QuixoteRacing.com. He KNOWS about that ole zbar stuff
Camber Compensator can be found at JBugs.com, Appletree.com, or look up Empi Camber Compensator.
Also, just Google: VW type 1 camber compensator and lots of pics will show up.
As for the z bar, I do not have pics but from what I remember from my Mark 4 and Mark 5, there were two short tubes that the z bar went through. On these tubes, there was a tab welded at an angle and mounted to the bolts that held the shocks. Then the bar was bent. On the ends we used aluminum clamps- rectangular pieces that had a slit cut so the clamp could compress around the bar and a 3/8 hole held the struts for the bar. Because of the distance between the mounts, we found that a center support was needed .
Hope that helps.
And Steve, I am not THAT old!
Dietmar
fvraceri@cox.net
www.quixoteracing.com
