I've searched the forums and haven't found anything, but really don't know how to USE that search capability either.
I have had a bear of a time finding an affordable welding helmet to use for my tig welding. If I can get set up correctly I can do a decent job of welding.... IF I CAN SEE what I'm doing. I've tried several different brands and ALL of them 'go beserk' rather quickly and start FLASHING me on/off erratically - from blinding me to total darkness - mostly because of the blindness from the arc.
I've been doing this for over 30 years..., but as I get older I need better vision to work with. My current 'YES' helmet seemed to work pretty well when I first got it, but letting it sit for 8 months or so and trying again, it is useless. Same result with several other models - some from HF, some off Amazon, but haven't convinced myself to drop ~$400 on a top of the line model just yet. I just don't weld often enough to justify it.
Anyone have one they LIKE and use INfrequently and it still works when you need it? I take the batteries out when not in use and keep new batts on hand, but it doesn't seem to be battery related.
Suggestions? Thoughts? I must have 6 or 8 helmets sitting around and none of them work the 2nd time I try to use them.
