Results 1 to 10 of 10
    Sacramento, California
    Liked: 100
    Default Rubber mark removal
    What do you use to get the rubber marks off your side pods and such? My car gets peppered with marble marks. Someone mentioned acrysol but that seems pretty aggressive. Suggestions?
    Liked: 3563
    Car polish or WD40 will usually do it.
    Liked: 289
    Default Rubber Remover
    Mothers R3 Racing Rubber Remover is what we use on the GT3 cars that run a lot longer with more rubber upchucked. Really bad we use VP Racing TAR remover but does leave streaks that need more cleaning.
    phil
    Michigan
    Liked: 240
    Tub o Towels to clean your hands at the track and save them to wipe down the car. They work like magic !
    Arizona
    Liked: 354
    I keep a spray bottle of Simple Green in my 'track consumables' box. That does pretty well between sessions at removing the black splotches created on cars paint from tire rubber. I spray that on the car and then into some kind of rag, like an old sock and rub car with it. WD40 is a good one also.
    The leading edge of the side pods on FE2 get 'sand blasted' pretty good. To combat this, I put a layer of Clear Bra on the leading edge and extend it back about 12". This has helped quite a bit on my side pods. You may consider some Clear Bra if you are getting some sand blasting in that area.
    Michigan
    Acetone works really well. I put it on a rag and wipe away.
    Administrator
    LaGrange, GA
    Liked: 37
    As posted above WD-40 works well
    Magic erasers work great too!
    Anderson, South Carolina
    General purpose adhesive remover. 3M makes some, but any brand will work. Also takes off any residue from inspection/run group/sponsor/etc. stickers.
    Liked: 904
    Quote Originally Posted by Gordy View Post
    agreed, like magic on rubber, just don’t rub too hard, there’s a mild abrasive in some of those towels
    Liked: 1189
    "Awesome" 2:1 dilution and a little elbow grease.
