This is a copy of a Mysterian M2 FV, built during 1997 to SCCA specs.
1st raced in May 1998, won ICSCC NW regional championship in 2000.
$3,200 OBO Located in the Phoenix metro area. **** STILL AVAILABLE ****
*** Something important I forget to include is that I removed and inspected the fuel cell when i was cleaning the chassis and it still has about 1/2 gallon of race fuel in it and it looks as good and thin as the day I stopped racing back in 2002, no foam deterioration, no fuel gum at all! ***
This has been sitting for a long time but i recently have gone thru it and cleaned it up and verified that all electrical items are working, including the starter.
To get it on the track it will need a minimum of an engine, rear shock, girling cylinders re-built, battery, belts webbing, tires.
I have full bodywork in buck status , ready for mold making, or the bucks could be re-worked to body panels again without a terrible amount of work.
I have a vast spare parts inventory, including tools, a long box with zero hours on its rebuild, 4 spare wheels with old mounted rains and lots more. If interested I can e-mail the spreadsheet to you.
Build highlights:
· Front End
· Front Beam has custom torsion spring and ¾” sway bar, race prep’ed spindles with offset bushings
· Front beam offset shock mounting kit
· Front brake drums with studs
· Centered steering with quick steer setup
· Rear End
· Short box with 1:26 3rd gear, 4.375
· Zero roll suspension (like the Mysterian) (missing the Fox Shock).
· Rear brake drums with studs
· Chrome Moly rear trailing arms
· Electrical - full wiring diagram included
· AMB Transponder - hardwired
· Master switch with ignition switch (have the wiring schematic)
· 6 volt starter with push button starter switch,
· VDO gauges for RPM, Oil Temp, Oil Pressure
· Idiot light for low oil pressure & high oil temperature
· Rain light with switch
· Remote battery plug-in connector 50A
· Dual aircraft temperature gauge for measuring CHT (Head temp) and EGT (Exhaust temp), CHT is switchable between L & R for dual probe setup)
· Engine
· Roxanne's Headers SS
· Roxanne's Collector 4-2-1 SS
· Cooling ducts, and engine tins
· No engine
· Cylinder head temp probes and exhaust probe.
· Hardware
· New composite light weight mirrors
· Fire Safety system
· No Battery
· 5 gallon fuel cell with custom aluminum cover
· Custom seat
· Sabelt 6 way safety harness - cam style (never used but belting dates have expired)
· Brake bias adjuster
· Other
· 4 – mounted wheels 4J15, old race tires
· Datasheets and setup sheets included
