I have zero Ackerman steering arms from velocityhaus.
https://velocityhaus.com/products/vd...9e36e551&_ss=r
https://drive.google.com/drive/folde...ao?usp=sharing
Can I just stack washers on the rod end to adjust this? If so where should I start?
Apologies if you already knew this, but ackermann and bump steer are separate concepts.
Bump steer is indeed typically adjusted by changing the vertical position of the outboard end of the toe link using washers above and/or below it.
Lots of youtube videos are online showing a variety of methods. A dial indicator on a stand, and a FLAT stiff sheet of aluminum sheet substituting for the rim is a basic "good enough" method at our level of racing.
You'll need two dial indicators in front of and behind the wheel center spaced approximately the tire diameter apart.
There are currently 17 users browsing this thread. (5 members and 12 guests)
