I'm getting closer on this car. Are the wheel nuts really the same on both sides?
Read the manual shows torque to 135ft/lbs
https://www.primusracingparts.com/Va...lock_p_92.html
Yep - same all around.
Never had one loosen at 110lbft - there will be other opinions for sure.
Make sure you have really clean mating surfaces, tight clean pins, and not worn out pin holes.
Any movement and I don't care what torque you use - it'll loosen up.
Remember the wheels dissipate brake heat too.
I learned torque 115 pounds. That's always been enough when I recheck as weekend progresses.....but I do recheck
And check torque AFTER the assembly has cooled down, not hot off the track
bt
There are currently 5 users browsing this thread. (1 members and 4 guests)
