Hi guys;
What is the size of the T Handle needed for removing the lower front inside wishbone? The bolt that goes into the chassis. Looks like a Torx but not sure?
Thanks!
Hi guys;
Thanks!
That looks like a 12 point NAS bolt with a hole in the center for safety wire. It'd be an imperial 12 point socket size. You might need a thin wall socket.
I use a 12 point 3/8 deep socket that I have machined down to fit inside the frame hole. I believe I may have had a car that required a 10mm deep socket with similar modification. I have also seen allen head bolts - yours looks to be as previously mentioned - a 12 point socket - probably 3/8.
The nut on the bottom is also hard to get a socket on. The problem is the hole will be very tight on most sockets and often epoxy has spread into the hole when the floor is replaced making it more difficult.
JM
RaceDog
Messenger Racing
Muleshoe, Texas USA
I use a 5/16" allen bolt with a jet nut- I also turned down a 3/8" deep socket to fit. At the risk of being told its dangerous, I put the bolt in from the bottom- much easier deal with. I'll risk the jet nut doesn't come off.
Thanks. Looks like the 12 point wrench may be the key. I’ll try the suggestions and let you guys know. Thanks again!!!
I'm a Formula Vee guy (since '85)...y'know...1950s caveman technology...
But this kind of stuff fascinates me. (machinist / machine builder for 35+ years).
Please keep us up on what you do and how it works.
Glenn
There are currently 19 users browsing this thread. (1 members and 18 guests)
