Results 1 to 12 of 12
    Late Braking Member
    Danville, California
    Liked: 232
    Default Kent Iron head thread sizes
    I'm servicing a Kent iron cylinder head, question -
    What are the "normal" bolt thread sizes for the intake, exhaust manifolds and thermostat housing?
    I can't remember the specifics and what I'm seeing doesn't seem right.
    Liked: 644
    Default Kent sizes
    As I recall, 5/16" UNC
    Late Braking Member
    Liked: 232
    All of them?
    So the M7 X 1 threads for the exhaust on my head are not original?
    San Diego,Ca
    Default bolts
    Yup
    Roland Johnson
    San Diego, Ca
    Derbyshire, United Kingdom
    Liked: 340
    All of them?
    As original, all those threads are 5/16 UNC. M7 is very unusual, especially in these circumstances as it's smaller than 5/16 (which is very close to 8mm).
    A common 'bodge' on this side of the pond is M8 in 5/16unf, because as well as the similar diameters, the thread pitch of the two is very similar.
    I really can't think of any reason for M7?
    Bay City, MI
    I’ve serviced a couple of Kent heads before, and from what I remember, the intake and exhaust manifolds usually take M8 x 1.25 bolts. The thermostat housing should also be M8, but honestly, it can sometimes be a little different depending on the year or if someone replaced them before. I’d double-check the threads and lengths, especially if what you’re seeing feels off—sometimes people swap bolts around over the years.
    Courtice, Ontario, Canada
    Liked: 134
    Nope, 5/16 UNC
    Stephen Adams
    RF92 Van Diemen FFord
    1980 Lola T540 FFord
    Late Braking Member
    Liked: 232
    So the best I can figure is a M7 X 1 helicoil almost fits in a 5/16-18 buggered hole and they had M7X1 stuff on hand. Only 3 of the 6 exhaust bolts holes where done this way and a M7 X 1 will tighten in a 5/16-18 hole. I was able to drill out/tap those 3 holes for 5/16-18 helicoils and repair the others so I'm good.
    I've been doing this long enough to see some amazingly strange fixes that defy logic and marginal mechanical skills.
  12. The following 6 users liked this post:
  13. #9
    Liked: 340
    Yes, the weird and wonderful never cease to amaze! Or, as someone once said to me about those individuals with marginal mechanical skills:
    "You spend your whole life trying to make things idiot-proof, then God comes along with a new kind of idiot..."
  15. #10
    Liked: 644
    Default head threads
    Quote Originally Posted by lbermud View Post
    Maybe you are working on a 2000 OHC Ford?
  17. #11
    Liked: 340
    The 2-litre OHC was Ford's first 'metric' engine, so the threads were M8 coarse, compared to 5/16" UNC of the Kent.
    The trouble is M8 and 5/16" are very close in diameter and pitch:
    M8 x1 is close to 5/16-24 UNF
    M8 x1.25 is close to 5/16-18 UNC
  18. #12
    Late Braking Member
    Liked: 232
    Default Stupid bolt tricks
    I found this single hand made M10X1.50 flat head "screw" holding the oil pump on the engine of my DB2. Apparently made from an 8.8 M10X1.50 hex bolt. When the only tool you have is a grinder you have to make do.
    I went to the local Ace Hardware and bought 2 proper bolts for $4.
