Results 1 to 11 of 11
    Destin FL
    Liked: 683
    Default Aluminum Expansion
    Gents:
    I will be using a Velocity Haus front ARB lever. Currently, it will allow the blade to slip in approximately 0.125”, but I am not willing to destroy the blade’s finish, so I need some advice.
    Heat will expand the Al, so my surmise is cold. Dry ice for 30 minutes or so?
    Petaluma, CA
    Liked: 585
    I wouldn't recommend using one of those Rick. I have seen more than one blade bar break one half of the blade off on the side where the adjuster was mounted. The better way to do this is make a clevis style post that mounts off the center lockbolt, thus allowing both blades to move freely. You'll need to machine a shoulder onto the bottom of the clevis so when it tightens up the shoulder acts as a guide in the bar housing and still allows the blade to rotate fore/aft smoothly. Hopefully this makes sense. See attached pic-
    Ethan Shippert
    https://www.norwestff.com
  3. The following 7 users liked this post:
    Destin FL
    Liked: 683
    Ethan:
    An elegant solution to a simple problem. Truly genius, Bud.
    Vancouver BC
    Liked: 484
    Since you're mounting to the centre of the blades, where would you fix the other end of the push/pull cable?
    In my car, there is a lever that mounts to the end shaft of the righthand side of the blade, outside the rod end for the pushrod, and the push/pull cable mounts on that same pushrod. So when the suspension moves, they both move the same amount and the bar therefore doesn't "adjust" with suspension movement.
    So with your centre-mounted adjustment lever, mounting the the push/pull cable to either side would mean there would relative motion of the bar when the suspension moves in roll or single bump/dip (you'd be fine in double bump). That would make the roll stiffness different for left and right corners.
    Liked: 1364
    Good point. Mine is like your.
    I like this cable connection so I hope there's more to the picture!
    Destin FL
    Liked: 683
    I was thinking about this.
    The blades are probably CrMo, and the lever is prolly forged 6061-T6. Softer, right?
    San Jose, Ca
    Liked: 112
    If you're asking is the alum softer than the 4130, yes it is. But the T6 isn't exactly soft, but it is softer than 7075. The 6061 machines well.
    Destin FL
    Liked: 683
    I will check with Greg on the specifics.
    Destin FL
    Liked: 683
    Wrong post
    Destin FL
    Liked: 683
    Gents:
    I spoke with Gregg today, and the lever is in fact machined 6061-T6.
    If I were to move to the ARB to center, I would need to:
    • fabricate an anchor at a chassis cross bar midpoint
    • fabricate a new lever
    • buy a new cable
    Gotta tell you Fellas, I believe what I have is satisfactory. Thoughts?
    Senior Member douglap1's Avatar
    Atlanta
    Liked: 96
    Gents:
    • buy a new cable
    Just make sure it moves easily without binding or preload. I recently discovered that one of the rod ends actuating my sway bar was set slightly longer than the other creating a pre-load in the bar making it very difficult to move when stationary. Easy to check and fix.
There are currently 7 users browsing this thread. (3 members and 4 guests)
  1. Extreme1,
  2. Greg H,
  3. Vulnavia
