Results 1 to 13 of 13
    South Carolina
    Liked: 712
    Default info on running FF in Mexico
    It looks like my Swift is going to Mexico, but the buyers have questions I don't know the answer to. If anyone has some information, I'd appreciate hearing from them
    Question one; Will carb jetting need to be adjusted going from the southeast [VIR, Roebling} to racing in Mexico City [2000m]
    Question 2: Apparently they only have 98 octane fuel. Is this a problem with the Kent engine?
    Question 3: They run on Toyo tires, but my buyers don't know anything about appropriate tire pressures or toe and camber. These are apparently street tires. Anybody run these?
    Question 4: Any info on Gearing for the tracks in Mexico. The F1 circuit looks like it will need a one over at least for 4th, but I am totally guessing. Anyone ever run down there?
    Many thanks for the help
    Swift DB-1
    Pittsboro IN
    Liked: 308
    Take this with a grain of salt but
    1. Absolutely
    2. It will be fine
    3. No idea
    4. More than likey gearing will not be as tall as you think because the altitude will limit the engine, although the thin air may reduce drag enough to make up for some of it
    They will need to talk to some locals even if they are in different classes
    Liked: 1199
    The Canadians run their Kents on Toyos and pump gas. I should think jetting would be different than U.S. avgas at sea level.
    We like about 2.5 degrees negative camber on our Toyos, run pressures 17-18 psi. About 1/4 inch toe out at the front and toe in at the rear. YMMV, but that's a good place to start.
    Savannah, GA (via Montreal)
    Liked: 931
    agreed, years ago we ran cdn FF on various brand street radials... they all have stupidly stiff sidewalls, so pressures were lower than typical; also to get any heat in them we ran LOTS of toe out and toe in. YMMV
    Prescott Valley, AZ
    Liked: 104
    Default DB1 Kent — Mexico
    There are several DB1s running in Mexico on Toyo tires. The FF series has a Facebook page “Club Vintage Formula Ford Mexico”, your buyer can ask the members.
    Vancouver BC
    Liked: 491
    One quarter inch?
    Total toe I'm assuming, but still: that seems like an awful lot.
    nwp
    South Carolina
    Liked: 712
    As always guys, many thanks for the information.
    Swift DB-1
    Liked: 1199
    Yes it is, but it works. It probably hurts straight-line speed but our tracks are pretty tight anyway.
    New Mexico USA
    Liked: 74
    Default Toe out definition??
    Tim H --
    Are you defining toe out at
    A) rim diameter or at tread diameter?
    B) total or per side?
    B). of course, makes the biggest difference (factor of 2!).
    Mississauga, Ontario
    Liked: 927
    I "think" Toyo publishes some info for these tires in terms of optimal pressures, tire temps etc. I've not seen it actually, but have heard tell of it.....
    cheers,
    bt
    Liked: 1199
    Quote Originally Posted by Lee Johnson View Post
    Tim H --
    Total, and actually at the length of the toe plate slots (don't have any right now to tell you that figure, but it's roughly 23", so maybe 0.6 degrees for 1/4 inch).
    Liked: 1199
    Given that the tires were made for street sedans of more than a ton I'm not clear what those optimums would mean for us.
    Senior Member Rondo's Avatar
    Delaware
    Liked: 22
    Default Jetting
    Jay Ivey told me he is very involved with the Mexican series. A quick call to him should get you the info you need from either Jay or one of his sons.
