Does the Tilton 61-777 with the 44mm bearing work with the Honda? There is little room for play or error and it seems that the bearing could get through the pressure plate fingers if the pedal stop isn't exact. It sounds like the old 52mm bearing can't be pressed into the piston of the 61-777 or I'd do that.
