    ohio
    Default Pinto 2.0l smoke out of upper coolant tube?!?
    I have a rather strange problem. The engine was recently rebuilt and only has break in time on it.
    Just got the car together and checking for oil pressure/ leaks. It hasn't been running longer than 30secs or so.
    https://youtu.be/D_aVyLHwuoQ
    https://youtu.be/WVtCug6rkoQ
    Is this normal for the pinto?
    There was some left over water / coolant in the block. Is it just heating up and coming off?
    Liked: 1609
    Anything that was in the head as a result of cleaning or machining is getting hot and vaporizing.
    I don't know what the point is of running the car with no water. If you are worried about oil system leaks then drive the oil pump with an old belt and pulley and a decent drill. Running it for 20 sec is only going to show you the gross leaks anyway.
    ohio
    Cool, Yea I was just looking for gross oil leaks before I took the time to put water/coolant into it. I will add that now. Thanks so much for saving the day for a new person!
    Mississauga, Ontario
    Liked: 916
    Default I do recall.....
    ....that savant Peter Egan did the same thing on every motor he rebuilt. Ran it in the car for a minute w/o coolant on its first start. I think he wrote about it in R&T when he restored his E-Type. Something about listening to the exhaust manifold crackle slightly as it cooled afterwards, while smoking a Marlborough and sipping whiskey
    It seems odd to me to do so. However, if it is good enough for PE, then......
    best
    bt
    ohio
    best
    bt
    That's freaking wild! Such a cool story.
    San Jose, Ca
    Liked: 111
    When I first install a new motor I don't bother with water either. I only run it for maybe 20 seconds to check for gross oil leaks. If its all good I fill up the cooling system, bleed the rad, and start it and top it up.
    Prescott, AZ
    Liked: 186
    Cannot imagine the water pump likes running dry.
    If it’s difficult differentiating between an oil and water leak some folks just remove one variable on start up.
There are currently 24 users browsing this thread. (9 members and 15 guests)
  1. beavertail,
  2. Bob Hatle,
  3. Bob Neumeister,
  4. BruceRace,
  5. Fred Michael,
  6. Mikey_hnh,
  7. Ron Doyle,
  8. Thomas Wirtz,
  9. TWells
