Results 1 to 5 of 5
    South Carolina
    Liked: 692
    Default info on running FF in Mexico
    It looks like my Swift is going to Mexico, but the buyers have questions I don't know the answer to. If anyone has some information, I'd appreciate hearing from them
    Question one; Will carb jetting need to be adjusted going from the southeast [VIR, Roebling} to racing in Mexico City [2000m]
    Question 2: Apparently they only have 98 octane fuel. Is this a problem with the Kent engine?
    Question 3: They run on Toyo tires, but my buyers don't know anything about appropriate tire pressures or toe and camber. These are apparently street tires. Anybody run these?
    Question 4: Any info on Gearing for the tracks in Mexico. The F1 circuit looks like it will need a one over at least for 4th, but I am totally guessing. Anyone ever run down there?
    Many thanks for the help
    Swift DB-1
    Pittsboro IN
    Liked: 284
    Take this with a grain of salt but
    1. Absolutely
    2. It will be fine
    3. No idea
    4. More than likey gearing will not be as tall as you think because the altitude will limit the engine, although the thin air may reduce drag enough to make up for some of it
    They will need to talk to some locals even if they are in different classes
    Liked: 1171
    The Canadians run their Kents on Toyos and pump gas. I should think jetting would be different than U.S. avgas at sea level.
    We like about 2.5 degrees negative camber on our Toyos, run pressures 17-18 psi. About 1/4 inch toe out at the front and toe in at the rear. YMMV, but that's a good place to start.
    Liked: 866
    agreed, years ago we ran cdn FF on various brand street radials... they all have stupidly stiff sidewalls, so pressures were lower than typical; also to get any heat in them we ran LOTS of toe out and toe in. YMMV
    Prescott Valley, AZ
    Liked: 82
    Default DB1 Kent — Mexico
    There are several DB1s running in Mexico on Toyo tires. The FF series has a Facebook page “Club Vintage Formula Ford Mexico”, your buyer can ask the members.
There are currently 19 users browsing this thread. (4 members and 15 guests)
  1. CARSHouston,
  2. McGinnis,
  3. Rick Kirchner,
  4. scott fairchild
