After many hours my 32/36 has a venturi that's rattling about. Are there any recognized fixes for this tat really work? I'm going to buy a new one anyway but I'd love to be able to use this one as a spare.
I can't help with this too much, but check out this guy on ebay https://www.ebay.com/sch/i.html?_ssn....m3561.l161211
I've bought lots from him and it's always been great and at good prices. He's in Bologna too.
A couple of Center punches on the non sealing side of the body has worked for me.
doesn't the carb still suck air around the venturi instead of through it?
Rick:
I would think so.
Contact Jim Inglese, jiminglese@proton.me, (203) 632-0659, https://jiminglese.com/jim-inglese-8-stack-systems.
Nobody on the planet knows Webers like he does. He has done 48 IDAs and 40 and 45 DCOEs for me. Excellent service, good Gent.
A couple of walks with a flat punch and hammer of your choice to the side of the carb works pretty well.
Some have used vert thin shim stock
Id think that a shim coupled with some thin high-temp sealant would be the way to go. Hadn't thought about shimming.
Don't use sealant on the inlet end - it might block the fuel passage.
Rick:
Another thought.
My new rear hubs are slip fit into the rear new upright bearings. That is to say, the hub flange effortlessly slips into the bearing race. As explained to me, the anodizing of the hubs were decorative in nature as opposed to MIL-SPEC. The difference in the two processes is a couple thou in diameter. Thus, the MIL-SPEC anodized is press in.
I contacted Loctite, and spoke with their racing tech, to understand there is a bearing adhesive to 0.020” to secure bearing ID/OD areas.
I have the two item part numbers (one, the sealant, one, the cleaner). Biggest issue: 400 Fahrenheit to break the bond. This will most definitely eliminate the air bypass issue, and a THIN coat might release easier.
Rick, the best solution I have found is to take the Venturi out and gently squeeze it in a vice (use soft jaws or a rag) perpendicular to the tube axis to deform and create a tight fit to the body at the port. Does a better job of sealing to the port and lasts longer than the peening of body. I’ll be at Buttonwillow this weekend if you want to talk about it. Todd
Thanks Todd! Unfortunately I won't be there. Hope you guys have a good event.
Small digression:
When I was making RF90-95 hubs I always had them hard anodized, not decorative. They were machined to compensate for the hard anodize thickness and were a shrink fit. If yours are a slip fit and not hard anodized I suspect you will have nothing but problems and they likely won't last long. Those 6 long capscrews will not be enough to hold them together. Your hubs are likely defective.
There are currently 13 users browsing this thread. (4 members and 9 guests)
