Results 1 to 24 of 24
    Detroit
    Liked: 81
    Default 2024 Open Wheel On-Board Full Race Videos
    Waterford 5/4/24-5/5/24
    5/4/24 Class Race
    5/5/24 Qualifying Race
    5/5/24 Feature Race
    Detroit
    Liked: 81
    Waterford Hills
    5/25/24 Saturday's Class Race
    Detroit
    Liked: 81
    5/26/24 Sunday's Qualifying/Class Race
    Detroit
    Liked: 81
    5/26/24 Sunday's Feature Race
    Detroit
    Liked: 81
    Grattan - SCCA Original Unrestricted
    6/15/24
    Detroit
    Liked: 81
    Grattan
    SCCA-Original Unrestricted
    6/16/24 Qualifying Race
    Detroit
    Liked: 81
    Grattan
    6/16/24 Feature Race
    Detroit
    Liked: 81
    Mid Ohio (Club)
    SCCA-IT Spec*tacular
    7/13/24 Feature Race
    Ferdinand, Indiana
    Liked: 148
    Quote Originally Posted by toolo4sno View Post
    Mid Ohio (Club)
    Hey! Hey! That's me at Turn 5 holding the double yellow on the pace lap. I saw you were registered as FE2. Did you get the 2.0 MZR upgrade installed? Last I heard you had the SADEV transaxle but still with the 2.3.
    I had lunch both days with those announcers. Nice guys.
    Good, hi-quality video. Not that usual 720p crap we get from our AiM SmartyCAM GP. I notice you don't have gear or tach display. Do you have an AiM data logger since you have the wheel? You can export the captured ECU data to CSV then maybe import it into your video editor; I've done that with Race Render.
    Dean Fehribach
    Co-owner: SCCA C-Spec Mazda 3
    Houston, Texas
    Liked: 31
    Default Setup advice
    Cool video..
    But you are really loose entry and mid corner. As a suggestion, at M-O I would not run more than 35mm of front ride height measured above the aluminum at the splitter with 7-10mm of rake with driver in car and 5 gallons of fuel. That is for the loose condition on corner entry. The car snaps mid turn on turn in. For this I would recommend 4mm toe out front total. Also, run the front anti roll blade at 45 degrees and the rear at the softest setting. These settings are based on 4 rounds of preload front and 3 rounds in the back with 1mm total toe in for the rear. Then adjust accordingly.
    Happy Motoring
    Detroit
    Liked: 81
    Mid Ohio (Pro)
    7/14/24 Feature Race
    Detroit
    Liked: 81
    No 2.0L for me yet. Still running the 2.3L and at this pace of racing it will take a bit to get the cash to afford it.
    I use newer GoPro Mini11s with a very custom setup and a separate power supply. When they produce video they are awesome, but they fail frequently and are not user friendly.
    This Mid Ohio weekend was the first race with my AiM gear all working. These videos took a while as it took a long time to figure out the CSV configuration for Dashware which I use to overlay the data. I could in theory do a tach now. I likely won't do the gear display until the new engine is in.
    Detroit
    Liked: 81
    Quote Originally Posted by Darryl Wills View Post
    Cool video..
    Happy Motoring
    I should use my brake bias adjuster more, but it's so unpredictable that I don't really know how much adjustment has been given. Especially, if I reverse the direction on the dial it can take three turns before it actually moves. That said, a simple forward one or two clicks may have helped that day at least as far as some corner entries went. I'll have to go through alignment/ride height figures. I also need to look into the adjustable rear ARB as right now I run unconnected which lifts my front wheel a lot.
    Detroit
    Liked: 81
    Gingerman
    SCCA Summer Speedfest
    7/27/24 Feature Race
  17. #15
    Detroit
    Liked: 81
    Gingerman
    7/28/24 Feature Race
    BLS
  19. #16
    Detroit
    Liked: 81
    Mid Ohio
    SCCA OVR August Sprints
    8/10/24 Feature Race
  20. #17
    Member GR93's Avatar
    Akron, Ohio
    Default Very Cool on board (like the announcers dubbed in too)!
    Mid Ohio
    Cool video! Do you have any from Sunday’s races?
    Thanks again,
    Denny
  21. #18
    Detroit
    Liked: 81
    Quote Originally Posted by GR93 View Post
    Thanks again,
    Denny
    Working on Sunday's Quali-Race now. I was going to race at Grattan this weekend then backed out; so they'll probably be done over the weekend into early next week.
  22. #19
    Detroit
    Liked: 81
    Mid Ohio
    8/11/24 Qualifying Race
  23. #20
    Akron, Ohio
    Hi Peter,
    Thanks for putting the race videos together, I really like the view and announcers talking at same time.
    Will you also putting together the final race on Sunday?
    Thanks again,
    Denny
  24. #21
    Detroit
    Liked: 81
    Mid Ohio
    8/11/24 Feature Race
    Took a little longer than expected. Plus I fell into a Youtube shorts hole.
  25. #22
    Akron, Ohio
    Mid Ohio
    Thanks Peter, appreciate you sharing your videos and I also enjoyed racing with you too! Look forward to doing it again sometime next year.
    BR
    Denny
  26. #23
    Detroit
    Liked: 81
    Pittsburgh International Race Complex - North
    SCCA End Of Summer Showcase
    8/24/24 Saturday Race
  27. #24
    Portland, OREGON
    Thanks for sharing buddy
