2012 Piper DF5 - Honda
$55,750
Contact via Apexspeed Messages or email: Michael.Bulzacchelli01@gmail.com
Up for sale is my 2012 Piper DF5. This car has been very well maintained and has raced as recently as 6/9/2024 with FRP at PITT.
The car has just been teched by FRP for the 2024 Season
Equipped with the Aim G-Dash with Evo 4 system (with many sensors and GPS) and Smarty Cam (all functioning correctly, camera starts recording when engine is started).
Custom 3D printed parts include 3D printed aerodynamics for camera and roll bar as well as special custom cooling fins to direct air into side pods (SCCA and FRP legal).
This DF5 has Front and Rear cockpit adjustable anti roll bars.
New Wilwood LD19 calipers with thermolock pistons (4 race weekends on them)
New Tilton Brake Master cylinders (4 race weekends on them)
New Fast Forward brake rotors (4 race weekends on them)
New Blueprinted wheel bearings by Fast Forward Racing (1 race weekend)
New Steering Column, rack, and steering wheel quick release (2 Race weekends since new)
Ohlins TTX shocks on all 4 corners (1 race weekend since rebuild by Alan Oleary)
No play in any rod ends or eye bearings on any of the suspension on car whatsoever (always replaced with Aurora)
Lithium Ion Battery
Dan Campbell custom airbox with KN filter along with Fast Forward racing Billet restrictor plate
Mylaps transponder wired into car and included
Serpentine and oil pump belts replaced Last season
Willans harness good through 2026
Excellent condition Ron Davis Radiator and 1 race weekend on Mocal Oil cooler
Quicksilver engine
Clutch disc, flywheel, pilot bearing, release bearing, pressure plate replaced 5 race weekends ago (Only used to get moving)
Car runs cool and has not had any issues with temp
Only thing that car will need to race SCCA is the FIA rain light (can currently race FRP without this)
Complete Speedcom Motorola CP200D Digital radio system. Wired into car with button on steering wheel. Includes headset and chargers as well (Everything that you will need besides helmet ear buds and Mic). Car has upgraded Aero antenna.
I will be including a binder containing manuals, setup sheets, data, parts diagrams, etc.
Log Book and bill of sale also included
The car includes a very thorough set of spares, most parts are new.
Here is a shared google drive folder containing more photos: https://drive.google.com/drive/folders/1RNicANWTjk7OS1i9ytKOQG8Be-3VJ-BF?usp=drive_link
List of additional parts included with car:
- 4 Spare Master cylinders (3 new, same as in car) (1 for clutch, 1 for FB, 1 for RB, and a different piston size that could be used for the a different brake setup)
- 6 New K&N Oil Filters (1010HP)
- Flat Floor Extension by Fast Forward Racing
- Brand New Side Pods still in original gelcoat (Upper and Lower)
- New Spare Ron Davis Radiator (Same as in car)
- 1 good used set of Slick tires (Only 3 heat cycles)
- 4 Almost new rain tires (Wrapped)
- 14 Total wheels (Including 4 on car) (2 are 2 piece, other 12 are the latest style Fast Forward wheel)
- 1 Set of White Vinyl numbers and 1 Set of Black Vinyl numbers
- 1 spare rotor in good condition bedded with PFC11
- 1 spare serpentine belt
- 1 spare oil pump belt
- 1 new spare clutch slave cylinder
- 1 spare release bearing
- Spare Mirrors
- 1 spare New K&N Air filter (same as in car with updated airbox)
- Stock HPD restrictor plate
- Spare hose clamps
- Spare Spark plugs
- Used spare shift joints
- 1 new spare wheel nut and 7 spare safety pins for wheel nut
- 2 additional used very good spare rotors (Unsure what pad was used with them)
- 2 new rear skid plates
- 2 used front skid plates (Some life left)
- Complete 3rd spring assembly
- Spare left and right front uprights and one rear which can be used on either side (early design),complete assemblies with good bearings etc.
- Dual radiators for dual rad setup
- 1 set of New Mintex MLB20 pads and an additional used set in very good condition
- 8 good used MLB19 pads
- Alternate/spare radio wiring
- 2 additional rotors used with Mintex pads
- Old style airbox and filter (snorkel setup)
- Rear gearbox quick jack mount
- 4 LD19 brake pad thermal spacers
- Spare battery (AGM unlike Lithium in car but good for spare)
- 2 car horses (Short, to hold car off ground)
- Hyperco 2”x5” (Fit shocks in car) springs: (4) 400lb/in, (4) 250lb/in,
(4) 350lb/in (2 of which are in car), (4) 300lb/in, (2) 450lb/in (in car)
- 1 2”x5” 375lb/in spring (unknown brand)
- 1 2”x4” Hyperco 250lb/in spring (for use with 3rd spring setup)
- Front and rear custom toe bars (complete setup to align toe on car)
- Pre-measured camber shim sets for rain setup
- 2 alternate style flat tie rods
- 1 Bag containing 18 bushings/spacers (all spare for mounting suspension arms)
- 2 new brake rotor bolt and floating nuts
- 1 full set of used brake rotor hardware
- 1 large box and 2 assorted bins m(costing $400+) containing all critical hardware (almost every bolt on car and all bolts that have any likelihood of being damaged in an accident), 85% are AN purchased from Pegasus Auto Racing
- 2 spare Aurora shift rod ends
- Set of spare pushrod adjuster and rod ends
- Carbon Fiber gearbox protector (slight damage but still good)
- Full set of Custom lead Ballast made to fit in floor
- Spare Battery Box
- 2qts of Redline gear oil
- 2 new Bottles of AP R2 brake fluid
- 1 can of high temp spray adhesive (used for any modifications to seat)
- 7 new sealed in box qts of Redline 20wt Race oil
- Alternate oil cooler setup (smaller Mocal cooler and lines)
- Spare New Fast Forward Braided Brake lines for each corner
- Spare Brake banjos (all same as in car for all MCs)
- Spare foam to seal sidepods
- Spare nose as well as the mold which can be used to make more of these noses of the updated design
- Gear Change tool
- Spare gearbox shift finger seals
- 2 spare shift fingers
- Spare gearbox hardware, 2 dog rings, and a set of sealing washers for drain and fill plugs
- 17 total gearsets all in excellent condition (including 4 in car)
- Spare Custom left air deflector
- Spare air deflector mount (Lower portion)
- Fuel cell measuring ruler
- Spare camera mount
- Spare gear selector shaft to shift finger attachment block
- Spare used steering rack (could use refresh but still operates smoothly, replaced with new unit in car)
- 8 Misc spare AN fittings and a few ft of AN10 and AN 12 oil line
- 2 Front Pushrod adjuster and lower rod end sets
- 2 right and 1 left upper A arm mount (Front)
- 2 spare sets of tie rod rod ends
- 1L and 1R upper A arm mount (a arm to upright mount)(Front)
- 1 Upper Front A arm (could be used for either side)
- 1 Lower front left A arm
- 1 Lower front Right A arm
- 2 tie rods (1 w/ends 1 w/out)
- 1 complete front pushrod with adjuster and ends)
- Misc camber shims
- 2 A arm upper mounts for back of rear A arms (to mount to gearbox)
- 1 rear upper control arm mount (to mount to upright)
- 2 Rear upper control arm front mounts
- 4 spare Aurora rod ends (for LCA)+1 LCA eye bearing
- 3 Rear Lower control arm front mount
- 1 lower rear control arm rear mount
- 2 rear pushrods w/out ends or adjuster
- 1 rear upper control arm (missing 1 eye bearing)
- 2 rear upper control arms complete w/bearings
- 1 spare axle
- 2 spare cvs
- 2 spare cv boots
- 2 spare cv clips
- 1 spare rear lower Right A arm
- 1 spare rear lower Left A arm
- 1 spare rear brake line aero guard
- 4 New PFC 11 and 4 used (ok) PFC 11 pads (Which is what is on all 4 corners of car)
- 2 front crash boxes
Spare parts that need repairs to be used but are repairable:
-Right Rear lower control arm
-Tie rod
-Complete side pod set
Car is Located in Northern New Jersey
Scale pad (Longacre) can be available for sale but will be sold separately from car
