The wheels have be picked up and will be used in a sports racer restoration. Thank you ApexSpeed.
NO SHIPPING. T he wheels must be picked up. They are located in Keizer, Oregon.
Front width: 6”
Front backspace: 2 ½”
Rear width: 8”
Rear backspace: 3”
Center hole dia: 2 ½”*
Pin circle: 3 ¾” *
Pin diameter: 3/8” *
* Measured with a short machinist ruler not a micrometer. The measurements are as accurate as I can get with the ruler but may not be exact.
Front wheels were fitted with 20.0 X 7.0-13” tires. Rear wheels were fitted with 22.0 X 9.0-13” tires.
One front wheel has a dent in the outer ring and will need to be replaced. The inner ring has a small distortion and should be serviceable. The second front wheel has small dent in the inner ring and may/may not be serviceable. The inner and outer rings on the rear wheels have no dents. Replacement rings are available on eBay for less than $100.00.
I know nothing of the history of these wheels. The Lotus EFDA that is on one side of the face of the center section. EFDA is an acronym for European Formula Drivers Association.
