I'd like to replace my rain light with a dual rain/brake system. I don't want to tap the brake line for hydraulic actuated switch. What systems have you guys figured out that works well with vintage formula brake pedals?
I may be a bit confused about your post. On my sports racer, all I did was use a simple pressure-activated switch, mounted between the caliper and the brake line banjo fitting. Took 5 mins to install, works just fine. Think I got it from Pegasus....
best,
bt
look up "backup alarm switch". Typically a spring wand operating a micro switch.
My GP Spitfire used a switch like this
Beck/Arnley Stop Light Switch - 201-1105 from Amazon
Had a small tab off the pedal in the linkage
worked fine for years
Steven Johnson used a reed (edit -- a mecury switch, closes when tilted) switch on Lola S2's, whenever the car slowed significantly, the switch activated turning on the brake light. You might need a magnet to turn it on for tech.
I've never seen a Vintage Formula car (or any formula car) with a brake light so your question is puzzling. Common/required on Sports racers though.
I believe Sovren requires a brake lights on all cars including FF. Several good options for you to look at.
The Austin Healey Sprite uses a T fitting on the brake line and a pressure switch available from Moss Motors https://mossmotors.com/542-110-switc...ed-pipe-thread
$10 or a mechanical switch from e- type Jag is available for $27 from Moss https://mossmotors.com/26-1005-brake...tch-mechanical
Regards
Paul
Most of us at Sovren run a banjo bolt brake light switch. Easy to add to the rear master cylinder and can be disconnected electrically when you don’t need it. No springs or rods mounted around the pedals..
https://www.pegasusautoracing.com/pr...asp?RecID=5028
if you use one of these, use some silicone where the wires come out of the switch as they are easily pulled out..
use this adapter if you have hardlines.
https://www.pegasusautoracing.com/pr...asp?RecID=4195
Flex line is a snap
scott, talk to Tracy - he has done a lot of work with this group
-John Allen
Tacoma, WA
'82 Royale RP31M
I recall reading that Steven also (actually?) used a mercury switch of the type that activates as it is tilted. One would need to adjust/calibrate the mounting angle so that a desired stopping deceleration rate (say 0.25g's) turns the switch on. Steven's intention was to avoid putting a pressure actuated switch in a brake line. His reasoning was that if not installed in the right orientation, they can retain an air bubble during bleeding & yield a soft brake pedal. A secondary effect would be that getting off the gas in a lowish gear ratio (or going down a steep hill) might turn on the brake light.
Lee
I used a small microswitch that has a soft spring lever that just bends after contact with the front side of the brake pedal.
