Results 1 to 12 of 12
    Oakland, California
    Liked: 78
    Default How do I buy a tachometer?
    Hey ApexSpeed community!
    I need to replace my mechanical tachometer. The gauge body of the one that came out of the dash of my Van Diemen measures 2.5 inches in diameter and the bezel that holds it captive against the dash measures 2 and ?-inches in diameter across the bezel. When I’m shopping for a replacement, am I shopping for a 2.5-inch tach or a 2 and ?-inch tach? Thanks!
    _______________________
    CornerSpeed
    1979 Van Diemen Club Ford
    Liked: 977
    Liked: 953
    I assume you are looking for a mechanical tach. I think I have one form a VD dash I bought some dyers back. I can check the garage Sunday.
    Oakland, California
    Liked: 78
    Default Electric tach
    Hi there, Steve. Thanks for your response. Actually, I am looking to replace the mechanical tach with an electric one.
    CornerSpeed
    Liked: 953
    I missed that in the OP!!!
  9. #6
    Liked: 281
    Default Stack
    I have a stack tack for sale but its body is 3.25 approx, 8000 rpm - just came back from Stack after needle came loose. $275 + frt
    Back in the day as VD importer thats pretty much what we replace the old small smiths unit with.
    Phil
    Sacramento, California
    Liked: 100
    Phil
    Sure it's not 80mm? If so and the original poster isn't interested I'd like to be next in line.
    Liked: 281
    Default Stack
    Sorry - they are 80mm body - you are correct. I have
    0ne 08-44 4 cyl 4 stroke. Scale is not compressed in lower rpm 8000 max $275 + shipping
    two 0612-44 Compressed scale to 6000rpm 12000 max $250 each + shipping
    I still have a test rig that I can verify that they work and are accurate.
    The 8000rpm tach also has new glass fitted during the needle replacement
    Phil
    Liked: 100
    Phil
    Interested in the 0-8K unit if the original poster is not. Can you send a pic to jwhite@sacnissan.com please?
    Oakland, California
    Liked: 78
    Default I yield!
    Thanks very much for your offer, Phil, but I’m looking to not have to modify my dash. So I cede to LastMinute and his interest in your tach. Sorry for the delayed response.
    CornerSpeed
  14. #11
    Liked: 281
    Default Tach
    I do have one of the original mechanical smith tachs with the 2.5 body if you need a working one. $150 + frt
    I dont think that there are any electric tachs that I would use at 2.5" body size with no dash mods. Bach in the day we actually went mostly with the big jones mechanical and redid the dash. The original smiths small tach was not well liked for various reasons.
    Phil
    Prescott, AZ
    Liked: 186
    Autometer digital with shift light. About 2+ in. dia.
