Results 1 to 26 of 26
    Glendale, Arizona
    Liked: 502
    Default Like new 1979 Dulon MP21
    Like new 1979 Dulon MP21 CF for sale
    One of a handful in the US that I am aware of.
    Frame up restoration 2017.
    Approx two hours track time in late 2017, early 2018 since
    Frame: Cracked checked and inspected.
    Wheels: 2 two sets Revolutions, stripped, inspected and recoated flat black
    New rod ends and heims
    Vintage Smith's mechanical guages
    Newly built Pat Prince lowers in front, some of his last and greatest work
    All suspension nickel plated.
    Shocks: Rebuilt to original specs by Performance Shocks, new springs
    Brakes: Period correct Girling 14LF Calipers. Completely disassembled, bead blasted, coated and rebuilt with new pistons, seals, and bleeder valves. New lines, fittings, Rebuilt Master cylinders, and new cockpit bias adjuster installed.KFP 5538 blue pads.
    New Momo 250cm Steering wheel.
    Radiators rebuilt , painted and pressure tested.New blue silicone hoses and SS clamps installed throughout.
    New fuel cell
    CV joints rebuilt with balanced bearings, new seals and boots. Inner and outer
    Gearbox: MK9, blueprinted, polished including 9:31 R&P lightened and polished.
    All new dog rings, all new studs, hardware and nuts
    New Gear
    Daddies engine to trans adapter plate
    Engine:
    No expense spared National level Ivey with less than two hours run time. Yes, all of the new things inside. Rebuild was nearly 8K, without cylinders needing any boring or sleeving. Head flow is amazing, Jay says one of the best Iron Heads he has seen, he will trade for AL head with cash back, it's that good. New Clutch including slave, master kits. New flywheel, rIng gear, push/pull throttle set up and more.
    Bodywork great, nice paint, no repairs done since new.
    Header coated in polished Silver, with 10 year unconditional guarantee
    New Battery with Tender hookup
    New Master Switch
    New Crow safety belts
    New oil pressure sending unit and LED warning light
    Much more done.
    Spares:
    Misc electrical and hardware
    All suspension parts may be used on either left or right side:
    Complete rear upright assembled to be bolt on part with bearings, hub, wheel studs, etc.
    Complete front corner
    Complete rear corner
    (2) new noses, in gel coat with splitters, never fitted or mounted
    (20) gear sets as new
    (2) dogrings new
    new KFP blue pad set
    SVRA Gold Medallion quality candidate, totally compliant
    Much more
    2 previous SCCA logbooks
    20K in parts receipts
    Set up notes
    15K
    Canton, Mi
    Liked: 46
    Default pictures
    New fuel cell
    New Gear
    Engine:
    New Master Switch
    Much more done.
    Spares:
    (2) dogrings new
    Much more
    Set up notes
    Many pictures during rebuild for interested buyers
    $24,500 OBO
    Will trade for Pinto or Zetec FC of equal value, SVRA B sedan Datsun 510, or water cooled SuperVee
    It might be helpful if you posted at least a few pictures.
    Glendale, Arizona
    Liked: 502
    Please send me a pm.
    I will email you an album of rebuild pics.
    Prefer to trade for water cooled SV
    Glendale, Arizona
    Liked: 502
    Bump.
    Price reduction to 21800 if bought before
    Chris' (Monte) FC sells.
    Unique car for all the 50ths next year.
    Will trade for Modern FC Pinto with spares and low time long rod engine......plus or minus cash either way.
    San Diego, CA
    Liked: 16
    Default Love some pictures
    I have a car for sale so I am not a buyer of yours, but I would love to see some pictures.
    Jim Haley
    619-992-5284
  9. #6
    Senior Member LenFC11's Avatar
    Houston TX
    Liked: 213
    Marshall
    I don't believe there are any other long rod engines out there.. they just got allowed into scca rules
    Chris ran f2k series where the powers that be allowed this in.
    Likely only Chris's car and whomever paid for the testing at QS to allow this in..
    Grab it while you can or pay for upgrade on any other car
    annndddd.. thank you for taking the Dulon from Ric.. that's one project I am glad I didn't get involved in.. you did a great restoration on it.. next owner will have a car to be proud of!
    Cheers
    Len
    Porsche River Oaks. Houston
  11. #7
    Glendale, Arizona
    Liked: 502
    Bump
  12. #8
    Glendale, Arizona
    Liked: 502
    Any interesting winged cars for trade?
  13. #9
    Glendale, Arizona
    Liked: 502
    18,500 firm
    Will consider trade for STD FM
    Glendale, Arizona
    Liked: 502
    Bump
    Senior Member reisertracing's Avatar
    indiana
    Default '96 vd
    I have a '96 winged FC Van Diemen I might want to trade. What is the size of your cockpit?
    See FC cars for sale. Thanks.
    Johhny Reisert
    Cincinnati, Ohio
    Default Rear Cowl
    Marshal
    Any chance you have a spare rear cowl for the MP 21.
    i could use one.
  17. #13
    Glendale, Arizona
    Liked: 502
    Unfortunately not. I get asked that a lot.
  18. #14
    Glendale, Arizona
    Liked: 502
  20. #15
    Senior Member captdigi's Avatar
    Phoenix, AZ
    Liked: 123
    Default Dulon
    Good Choice!!????????????????
  21. #16
    Glendale, Arizona
    Liked: 502
    17K
    Any less, I will part it out.
    This engine is National level, legal 2 hrs. run time.
    Transmission 2 hrs on blueprint with
    20 gear sets plus two new unused dog rings.
    14LFs newly rebuilt.
    Every suspension component has a spare,new, plated and ready to go, including rear upright with bearing, hub, spindle, bolt and go. Shocks rebuilt and dynoed 2017, 2 hours.
    2 sets of wheels
    Two new noses in gelcoat.
    New seatbelts, fuelcell, everything.
    No better or rarer car for 50th.
    Last offer....17K.
    At this number, I am taking a 10k loss on parts alone, plus hundreds of hours in prep.
    I am changing to FC and need the room in the shop.
    Call Ivey and ask about this motor.
    Not negotiable on price.
    You can buy a cheaper car, but not at this prep level.
    One 3 session set of R888s with purchase.
    Will run October PASA race with purchase for 1k more, to include engineering and coaching after purchase.
  22. #17
    Santa Ana
    Liked: 263
    Killer deal!
  23. #18
    Glendale, Arizona
    Liked: 502
    Ran the car two weeks ago at Willcox, AZ.
    No issues.
    Engine time now 3.5 hours.
    SCCA logbooks and custom car cover included.
    Car will be prepped this weekend, with fluid changes, aligned and scaled.
    Also, now have added custom string alignment bars to the package.
    16.5K
  24. #19
    Glendale, Arizona
    Liked: 502
    15K
    Great unique car for 50th.
    Put your gear on and go.
    Prepped, aligned, scaled, fueled and ready to go
  25. #20
    Glendale, Arizona
    Liked: 502
    12k
    I am addicted to FC
    So,
    2.5 hour 7800.00 Ivey rebuild
    2.5 hour MK9 blueprint
    20 gear sets/new dogs installed/2 new included
    You will not be dissappointed.
    Will include orientation weekend full support for additional 2k
    I have receipts for 2X this money invested, plus labor
  26. #21
    CA
    Liked: 262
    Marshall, please give me a call. Todd Strong 562-627-5048
  27. #22
    Houston TX
    Liked: 213
    Smoking deal. I'm surprised it's not spoken for
    Cheers
    Len
  29. #23
    Glendale, Arizona
    Liked: 502
    Sold, pending payment
  31. #24
    Canton, Mi
    Liked: 46
    Is it possible that car is staying on the west coast?
  33. #25
    CA
    Liked: 262
    Default Coming to SoCal
    Yes, car has completed trip to SoCal. Dealing with Marshall was a pleasure and car was as represented. Todd
  34. The following 5 users liked this post:
  35. #26
    San Diego, CA
    Liked: 16
    Default Two FFs
    Are you going to keep the Titan and campaign two cars?
    Jim Haley
    619-992-5284
