Results 1 to 14 of 14
    WA
    For Sale SOLD Protoform P2 with Enclosed Trailer
    SOLD!!
    #69 Protoform P2 for sale with 6x12 enclosed trailer. Has SCCA logbook. Car handles great and has always been a fun car to drive.
    $5500 car only
    $6500 with trailer
    Recent history: Purchased from AVR motorsports in Canada. Raced 6 weekends with conference in 2016. Raced at CotA super tour finishing 4th on Sunday.
    Engine: Noble engine with a Kapelke intake and Noble carb. Rebuilt by Vallis Motorsports, New piston and cylinder set before CotA weekend. Pertronix ignition.
    Transmission: Vallis built short box
    Beam: Height adjuster installed.
    Suspension: Rear penske double adjustable shock. Front penske blacks.
    Tires: 1 set mounted hoosiers with 5 cycles. 1 set of mounted new American Racers. 1 set of mounted hoosier rains. At least 4 more spare wheels. Will also include the canadian spec Falken 615K with wheels if wanted.
    Dash: Mycron Gold 3 data acquisition
    Cooling: modified top scoop to bring in more air to an over sized remote cooler. No issues with cooling on this car, max temp seen of 240.
    Safety: New fire system in 2016, OMP harness good through 2020
    Spares: Battery, spare nose, points distributor, valve cover, pushrod seals etc. Will include everything VW I have
    Built a seat with 2 part foam and have enough left to make atleast one more.
    Trailer: 2012 Cargo Mate 6x12 single axle. Ugly but light and mechanically in good shape everything works. New wheel bearings and also spare hub with bearings. Tire rack that holds 2 sets of FV wheels and tires, trailer worked great on the 4000 mile trip to Austin and back.
    Car is currently in silver and blue trim. Willing to deliver within approx. 500 miles of Tacoma area.
    Would also sell without the trailer if wanted.
    Andy 253-381-8713
    alabama
    Liked: 163
    Would you like to sell The treaded street tires with wheels.
    WA
    Yes, I would sell the street tires but not sure about shipping them across the country.
    Schellsburg, PA
    Liked: 123
    The paint job is spectacular. The air scoop will fit a conical filter from I believe an S2000. It also has a cockpit opening that is about 10" longer than a stock P2, which makes getting in and out way easier. Unless it's been changed it also has a motor mount that allows you to remove the motor and gearbox as a unit.
    Member GrahamLoughead35's Avatar
    Carmel, IN
    Liked: 34
    what year is the car?
    WA
    1999? Not really sure.
    Schellsburg, PA
    Liked: 123
    The car is a '92 or '93 it was the 7th Protoform built... It has the P1 trailing arm mounts. Later models do not have the mounting brackets
    WA
    Still available. 6500 with trailer.
    Colorado
    Sent PM, thanks!
    WA
    Still available. $4500 someone come and get it.
    NY
    Quote Originally Posted by handyalbert11 View Post
    sent PM.
    open question to forum......Protoform P2- able to fit a 6'1" 190LB driver?
    thanks
    NH
    Liked: 67
    I am 5' 11" 240lbs and fit in a protoform that is very similar to this one.
    its a little hard to say for sure that you will fit since the height of the roll hoop could have been changed on this car or my car over time. The best thing to do is sit in the car if you can. If you are too tall you will need to move the seating position so your knees are bent more or have the roll hoop modified.....
    Golden, Colorado
    PM sent, Interested.
    WA
    Car is Sold
