******SOLD**SOLD**SOLD******
For sale by original owner>
Unique 20’ Pace Shadow white tag trailer, heavily optioned & custom ordered on November 2004 for use as a stacker trailer with an aluminum Rexxon Formula Car/Sports Racer elevator.
Tows like a dream, compact transport for tight driveways and even tighter paddocks!
Fairly low mileage…been sitting for the past 3 years, and we are local SoCal racers typically averaging only 5-6 race weekends/year. We did go to the Runoffs in Topeka 1x, otherwise only SoCal tracks.
Only 99” tall (exterior height)!
79" interior height
81” between wheel boxes
96” interior width
19’ 7” interior floor length
Two 5,000 lb tandem axles
Reese weight distribution hitch w/built-in cam-style anti sway
Aluminum 6 lug wheels
Spare tire & wheel
Maxxis 225x75x15, “D” rated tires, near new tread, about 4 yrs old, & I’ve always used tire covers when stored.
All wheel electric brakes, serviced about 500 miles ago.
Polished SS front corners
All LED running/brake/clearance lighting
TWO! 48” man doors (one on each side so you can work out of either side of the trailer)
2 Exterior GFI 110v outlets (one on each side)
2 Interior 110v wall outlets (one on each side)
1 Interior 110v ceiling outlet (for reel mount cords)
2 Interior 110v dual tube fluorescent fixtures
2 Interior 12v incandescent fixtures
30a breaker box & 25’ shore power cable
1 x 14x14” vent/hatch
White aluminum walls
White vinyl ceiling
Diamond plate floor & ramp
12 Factory installed recessed D-rings
Factory installed recessed E-track on floor
All 3 interior walls lined with 2 rows of E-track on every wall
2 “basement” compartments, approx. 3’ x 3’ x 1’ (spare tire in one of them, but plenty of room around it for storage)
3,000lb winch installed on factory winch plate
Aluminum organizer on curbside door
Aluminum 2 helmet rack/suit hanger
2 aluminum 2 fuel jug holders (4 jug capacity)
5 aluminum tie down strap holders
2 aluminum cord/hose holders
Funnel holder w/ funnel
Fire extinguisher mount on door
Craftsman “roll away” tool box included
This trailer was also optioned with removable Pingle motorcycle floor mounts, enough for 4 bikes (only enough room for bikes if the elevator is removed though)
Also included with trailer>
10 pcs E-track D-rings
8 pcs E-track straps
Optima yellow battery w/5’ leads and 50 amp plug, used to operate lift, winch, & lights
Aluminum Rexxon Formula Car/Sports Racer elevator, 12v
Elevator only weighs about 500 lbs
Have all original instruction sheets
We carried two SCCA Sports 2000’s with spares, 1 set extra wheels each, and 1 spare nose each.
Will accept almost any Formula car also (FV,FF,FC, & ?)
Can also be used for 1 car + a quad….. or even more spares. This elevator lets you use the entire volume of the trailer that is normally wasted space above the car.
Downsides>
Some typical scuffing of the walls from use
1 clearance light is not lighting
1 aluminum wheel is ever-so-slightly not the exact same as the other 3 wheels (you probably wouldn’t have noticed it unless I mentioned it)
1 “ding” in the pass side exterior lower wall, rear of wheels (car backed into it while at a gas station)
1 “ding” in the driver’s side upper corner, on the polished stainless steel (tree branch came down on it while parked!)
A few more typical dings here and there, and a few minor paint scrapes from EZ ups and such.
Turnkey trailer w/ elevator> $10,000 with WD hitch assy, Craftsman toolbox, E-track & E-track hardware, and many of “pit-pal” style accessories (of various brands)….well over $1,000 of extras AND the hard to find elevator. This is a really sweet way to haul (or even just store) 2 Formula cars or Sports Racers. My racing days are over, and this is all I have left (other than some GREAT memories!).
