I'm on the fence on purchasing a couple brake pressure sensors for my CDS copilot 2+ or just using the on-board long G forces to review my braking points.
I reviewed a data file that comes with the CDS software and noticed that the longitudinal G force graph matched pretty darn close to the front brake pressure sensor graph. Sure, having the two brake pressure sensors would allow some additional info such as observing if a problem with the brake system is in the rear or the front by reading the pressures but not sure if there is much more to gain from adding brake pressure sensors when you can clearly see where you might be able to brake a little more efficiently by watching the g forces. Am I wrong? Perhaps using the longitudinal g force with a plunge type sensor on the brake pedal together would be good enough? I already have an unused plunge sensor that could work on the brake pedal.
