A very nice, clean example of the popular and affordable F300 Series, and only a 2-owner car. Was originally purchased by a professional racing team; GTA Motor Competicion in Valencia, Spain whom owned the car for 10 years before being sold to a private party for hillclimbs in 2011.
The car only competed at 5 hillclimb races in 2011 and 6 in 2012, so the engine has only covered 180 km's since its last rebuild when purchased. This Toyota engine is the Piedrafita Long-Life motor which is good until 10,000 km's, (6,200 miles) before its next rebuild, incredible reliability!
The car has the air restrictor tube removed for increased horsepower, still has the airbox mounted. Engine had a dyno test with great figures 5 months ago and has only done 4 hillclimb races since.
Engine: Toyota 3S-GE, 2 liters, inline 4-cylinder, 236 hp @ 7400 rpm
ECU: Magneti Marelli MF4-L and the MT940 Digital Display
Gearbox: 5 manual speed Hewland F3A, clutch shaft was replaced and it only has 2 races
Aerodynamics: modified Double Twin Rear Wing Element, so you get an extra main plain
FIA FT3 fuel tank, in-date FIA homologated seat belts, in-date FIA fire extinguisher
Dampers: Koni 28 Series, 2-Way Adjustable
Slick tires have very low usage, (50 km's)
Spares Parts Package Included in Price:
1 Set of OZ Wheels on Avon Rain Tires
2 Sets of OZ Wheels on Avon Slick Tires
1 Set of OZ Wheels on Dunlop Slick Tires
2 Sets of OZ Wheels on Dunlop Rain Tires
2 Sets of Technomagnesium Rims no Tires
1 Eibach spring for circuit racing (1100 lb/in)
2 Eibach springs for circuit racing (1000 lb/in)
2 Eibach springs for circuit racing (900 lb/in)
2 Eibach springs for circuit racing (800 lb/in)
1 Front Wing Assembly
1 Rear Wing Main Plain
1 Clutch
1 Flywheel
2 Clutch Rings
2 Wiring Looms
20 Gear Ratios
1 Primary Shaft
2 Gear Selector Forks
Many Sets of Brake Pads
Suspension Bars & Geometry Set Ups
Dallara Manual
Koni 28 Series Manual
Hewland F3A gearbox manual
Set-up Sheets and Gear Chart Calculator
Engine Dynosheet
For Sale at $33,000 OBO
Reduced to $28,800 OBO (with Reduced Spare Parts Package)
