Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
  1. #41
    Valley Hi,Ohio
    Default Pressure not streamlining
    If you enlarge the photo of the Fit(mine is white)you will notice that the roof line and the rear spoiler are at about 15 to 20 degrees to each other.You are not streamlining you are moving the amount of pressure around.
    The spoiler keeps the air moving in a slightly upward angle(little drag) but at the same time speeds up the air from under and sides said trailer to fill the gap reducing drag and lift at the same time.You are trying to make the air going under the car or trailer travel as far and fast as the air going up and over to equalize the pressures as much as possible.The very little drag added by the spoiler.
    Without the spoiler the air from on top has to fill the big gap left behind witch causes a lot of drag.The spoiler makes the air from around the rest of the car,trailer or what ever help fill the gap causing less drag and lift.
  2. #42
    Stuttgart, Germany
    Don't forget that there are non-drag/lift reasons for aero devices as well. There are lots of features on modern cars that are not drag devices, but do reduce dirt build up (soiling) or wind noise.
    -Robert
  3. #43
    Valley Hi,Ohio
    Default This one isfor Aero!
    This one is for drag reduction and one similar for the same reasons on most SUVs or similar shaped cars.
    Lee
  4. #44
    Austin, Texas
    Okay I'll buy the arguments.
    Where do I get an appropriate spoiler wide enough for the trailer and how much will it improve my fuel mileage?
    Will it really help stability?
    Dean
    Wolf GB08
    Austin
    www.motorsports-sw.com
  5. #45
    Liked: 1521
    since it's hard to find a 96" shear and brake wouldn't you just cut and bend two 48" pieces and lap the seam with about 8 rivits?
    It's not gonna go 200.....
  6. #46
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Instead of looking for a shear and brake that long, I am entertaining making one out of aluminum with angled brackets or thin plywood.
    Or-using an off the shelf one made for our roundy round brothers in aluminum or lexan:
    http://pitstopusa.com/i-5067782-alls...er-5-x-72.html
  7. #47
    Liked: 3342
    Default Photos of things that (supposedly) work
  8. #48
    VA
    Do you guys spend as much time developing your race cars as you do developing your trailers?
  9. #49
    Valley Hi,Ohio
    Default yes
    If you only new!!
    I think Dave's car has been developed a lot over the years!!
  10. #50
    Valley Hi,Ohio
    Chicago
    Save the wax..
    Put these on the back of the trailer.
    http://www.airtab.com/main.html
    could you use them on a racecar?
    Reinventing the world, one wheel at a time.
  12. #52
    Markham, Ontario
    Default Yes
    Quote Originally Posted by jhenn4716 View Post
    And I do.
    They can be used to delay separation and straighten flows. Minimal benefit.
    Tom Owen
