SOLD!!!!!!!!!!!
To makes this more of a ridiculous deal...
FREE delivery in the CONUS up to $1,500 or if you don't need delivery, put the $1,500 towards the price so $32,500!
This car really is one of the nicest in the country regardless of chassis number with SCCA Enterprises and several CSRs willing to back that statement up so please read on if you want a clean and winning FE....
Offered at $34,000/best is my loaded FE chassis #31. This car has been professionally maintained with no expense spared on upgrades or maintenance and has ALL THE TOYS including those that you will not find on any of the other cars that have been for sale like the FIA Head Surround, full paint (no gelcoat here), Star Mazda Tripod Housings, Star Mazda Hub bolts, Chase Cam video system, extensive CDS DATA acquisition system, etc. Really, NO expense was spared on this car!
The engine was on the Enterprises dyno 2 race weekends ago and is one of the strongest they have seen so it is ready to run for a long time to come and a proven winner. This is a well-sorted and consistently winning car at national events (won the Rocky Mountain Division in 2010 and finished 5th in Nation Points). Extensive rebuild of car for 2010 season including all wear items and full inspection (stripped to frame). This is a ready to race package that just needs a prep and new owner to hit the track! Read on for full details or call Carl at 303-885-4458….
Upgrades:
*CDS Co Pilot 2 Data system/dash installed in ’08 reads all ECU feeds (Throttle, Voltage, Water Temp) plus GPS, Steering Angle, Wheel Speed (one wheel), Oil Temp , Fuel Pressure, and Air Fuel Ratio for power tuning.
*ChaseCam PDR-100 video system, latest version with Auto-Record, G-Force Module, and custom composite camera pod on top of roll-hoop cover.
*Wired for radio system.
*LED rain light.
*FIA Head Surround (one of the few cars that has this part).
*Painted in Renault World Challenge livery with engine turned and clear coated wings.
*Taylor Gearbox.
*Silicon Hoses.
*Aeroquip on everything.
*Momo Wheel.
*AN Bolt Kit.
*Camlock body fasteners.
*Fuel pressure regulator relocated to throttle body.
*Radiator Screens
*Cockpit Liners
*Pro Mazda Outer Tripod Housings.
*Pro Mazda Rear Hub Bolts.
Updates…It has ALL of them including:
*Crush Box
*Adjustable Front Bar
*Floating Rotors
*PFC Pads
*Steering Shaft
*Latest Taylor Input Shaft
*Aluminum Belly Pans
*30 Amp Battery
*Rear Wing Support Block Kit
*Current Wing Endplates
*Shift Cable
*Fuel Filter
*Fuel Pump
*Fast Forward Axles.
*Fast Forward Wheel Nuts.
*Differential Carrier.
Lots of spares including:
*Momo wheel with Pi Dash (great backup dash).
*Painted Front Nose (New)
*Front Upper Suspension Arm (New)
*Front Wing Plane (New)
*5th Gear (New)
*3rd Gear (New)
*Complete set of rebuilt injectors.
*Lots of spare AN bolts.
*Fuel pump.
*Left sidepod cover (repaired).
*Radiator (repaired).
*15Amp Battery.
*All sorts of FE specific fasteners, circlips, etc.
*3 rebuilt wheel nuts.
*Tripod Set (New)
*Iridium Plugs (New)
*Axle Boots.
*Axles.
*Input Shaft.
*Misc gears.
*Plenty of stuff that I’m missing.
*Ballast.
Includes:
*Rechargeable booster pack.
*Comprent Toe Bar Set.
*3 complete sets of wheels.
*1 set rain tires with one session.
*Nose Transport Brackets (mounts nose backwards on top of shock cover).
*Custom fitted rain cover (the best).
*Comprent gear service tray (holds gear stack and bearing carrier for service)
*Comprent gear service pin (aids in removal of gear stack and holds stack upright for service).
*Comprent tripod greasing tool.
*Plenty of new filters and misc items that I'm forgetting about but you get it all!
Eric or Mike at SCCA Enterprises will happily vouch for the condition of this car.
Additional pictures can be provided on request.
If you are looking for a top notch winning FE, don't miss this one!
