Hi everyone. After a ton of discussion within our MC engine proposal committee as well as much discussion with several engine builders, we have finalized our proposal that we will send to the CRB very soon.
We are posting our proposal here and on EformulaCarNews to get feedback from those who are interested in the subject. Please read the entire post. We welcome your comments and suggestions.
You will note that the committee has unanimously agreed on every aspect of this proposal. There are several VERY KEY elements within our proposal that we hope will convince everyone that our intentions are to make F500 a better class with more opportunity for growth in the future and that we are absolutely serious about parity between the 2 stroke and the 4 stroke engines.
The major change to our rules porposal is that current and future 600cc MC engines will be restricted by the use of an Individual Inlet Restrictor (IIR) between the inlet manifold and the cylinder head at each inlet port. This will assure that there will be parity between the various engines used in F500. This part of the rules is the result of extensive discussions between members of the committee, several engine builders and members of the CRB.
Another change to our rules proposal has been to allow the use of aftermarket ECU tuning modules. This is because they will be needed to properly tune the fuel map as a result of the use of the Individual Inlet Restrictors.
To: SCCA CRB members
Subject: A proposal to allow the use of 600cc motorcycle engines in Formula 500.
Committee members
George Dean
Chris Huskamp
Clint McMahan
Dan McMahan
Leon Mitchell
Jim Murphy
Jay Novak
Jack Walbran
Statement of Purpose:
· To allow the use of stock production 600cc motorcycle engines for use as ALTERNATIVE ADDITIONAL engines for use in Formula 500.
· It is the intent of this rules proposal that the current F500 Rotax 493 and non RAVE 494 2 stroke engines remain the competitive benchmark for competition adjustments to F500 when 4 stroke motorcycle engines are allowed into use in F500. To that end all motorcycle engines allowed into F500 for use, as alternate engines in F500, shall be restricted by the placement of a defined restrictor between each cylinder throttle body and each inlet port. This restrictor will be used to initially restrict the horsepower of all motorcycle engines to a TBD HP level and to limit future growth of the maximum HP of these engines. The initial size and shape of the defined restrictor shall be determined by dynamometer and track testing of a representative engine or engines. The restrictor size will be adjusted by the CRB over a period of approximately three years in order to achieve and then maintain competitive parity between the 2 stroke Rotax engines and the 4 stroke motorcycle engines.
Background:
As many of you are aware several members of the Formula 500 community have formed a 600cc engine rules committee to try to define a working set of rules for the use of 600cc 4 stroke motorcycle engines for use within the F500 class. We have essentially used the engine rules for FB (F1000) with several additional requirements to control engine costs and performance.
F500, while a popular formula car class, has a relatively limited appeal to the greater formula racecar community due to many factors. These factors are concerns for many of the potential competitors in F500.
1. The 2 stroke engine and it's associated sound
2. Questions concerning the long term viability of the 2 stroke engine
3. No access to new 2 stroke engines
4. Limited access to used 2 stroke engines
5. The CVT transmission and its associated tuning challenges, which can be a significant barrier to entry, for new competitors.
6. No shifting due to the use of the CVT transmission
It is very interesting that the fastest F500 cars are now as fast as the fastest F-Fords at about 1/3 the cost of a new F-Ford. You would think that this would provide for one of the most popular formula classes in the SCCA. The reality is that F500 is presently the LEAST POPULAR formula class in the SCCA and has been close to the edge of National Status several times.
Class Rank, Class, National entries (2008)
3, FV, 581
4, FF, 430
7, FE, 353
8, FC, 337
10, FM, 316
11, FA, 295
13, F5, 276
Some competitors believe that access to snowmobile engines is a key element in the limited growth of F500. One of the reasons for this may be the relatively limited sale of snowmobiles across the US. For example:
1. In 2007 there were 1.12 million motorcycles sold in the US
2. In 2007 there were 79,815 snowmobiles sold in the US.
3. That is a Ratio of over 14 to 1 for total motorcycle to snowmobile sales
4. The estimate for the sales ratio of 600cc motorcycles to 500cc snowmobiles is at least 40 to 1 (from dealer estimates of sales)
5. Snowmobiles are sold ONLY in northern states and this dramatically limits their availability in other parts of the country.
6. There is NO QUESTION that there is concern about 2 strokes being legislated out of existence. Yes, there are companies that are continuing to build 2 stroke engines but the vast majority of manufacturers are now switching to much larger displacement 4 stroke engines, further restricting the future availability of 2 stroke engines.
New, younger, competitors that we want to race in our class are not coming to F500. Direct comments are that they want “racecars that shift”. and they “do not want to work on the clutches and maintain 2 stroke engines”.
The 600cc engine committee is confident that if 600cc motorcycle engines are approved for use as alternative engines to 2 strokes in F500, the growth of the class will be significant. When the first F500 car with a 600cc motorcycle engine was shown at the ARRC at Atlanta for show and tell, the car was BURIED BY INTEREST. At least 200 people were seriously interested in the project and the potential of the class. 2 former National Champions from other formula classes indicated that they would switch to this class if the bike engines were allowed. Numerous competitors offered deposits on the purchase of F500 cars with motorcycle engines. The interest level was amazing to say the least.
After posting pictures of this chassis with the 600cc motorcycle engine on ApexSpeed, there have been over 10,000 views on ApexSpeed on the subjects of these engines for use in F500. The best part of all in this interest is that the VAST MAJORITY are from people who are not now involved in F500 but could certainly become new competitors. Please see this link to the many posts on the subject. [
Again, the committee is confident that we can make the 4 strokes and the 2 strokes competitive. They have about the same HP and about the same weight, so if the cars are competitively balanced, you can race a 2 stroke if you want or you can race a 4 stroke if that is your interest.
Also note that our efforts are intended to make CERTAIN that current F500 cars remain absolutely competitive and that the class philosophy of the absolute best value in low cost racing is maintained or even improved.
We have based our proposed engine rules on the current F1000 (FB) rules drawn directly from the 2008 GCR. If this proposal is approved the engine rules set would be integrated into the existing Formula 500 rules.
Proposed 600cc engine rules, this is a draft proposal and is open to changes as appropriate.
E.15. Alternative Motorcycle Engines
A. Mass produced (Honda, Kawasaki, Suzuki or Yamaha) water-cooled, 4 cylinder, 4-cycle motorcycle engines up to 600cc. The list of approved manufacturers may be modified by the CRB.
B. The current F500 Rotax 493 and non RAVE 494 2 stroke engines shall be the competitive benchmark for competition adjustments to F500 when 4 stroke motorcycle engines are allowed into use in F500. To that end all motorcycle engines allowed into F500 for use, as alternate engines shall be restricted by the placement of a defined restrictor between each cylinder throttle body and each inlet port. This restrictor will be used to restrict the horsepower of all motorcycle engines to a maximum TBD HP level. The initial size and shape of the defined restrictor shall be determined by dynamometer and track testing of a representative engine or engines. The restrictor size will be adjusted by the CRB over a period of approximately three years in order to achieve and then maintain competitive parity between the 2 stroke Rotax engines and the 4 stroke motorcycle engines. (see E.15.O for additional information)
C. All engine internals and compression ratio must remain stock. The competitor must present, on demand, an original factory manual for the engine to allow compliance verification. There shall be no modifications of any component of the engine unless specifically authorized in these rules.
D. The stock ECU shall be used. The ECU fuel map may be changed. Devices that modify inputs to the ECU (e.g., Power Commander) may be used. Stand-alone after market ECUs are not permitted.
E. Turbochargers and superchargers are prohibited.
F. Carburetion or fuel injection may be used. Fuel injection if used must be stock and unmodified for the model and year of the engine that is used.
G. The exhaust system and exhaust manifold are unrestricted, within SCCA safety regulations, except that stepped exhaust headers are not allowed.
H. The lubrication system is unrestricted except that dry sump systems are not permitted; any oil pan and/or baffling are permitted and the use of Accusump or similar oiling assist systems is allowed.
I. Oil coolers are unrestricted.
J. The cooling system is unrestricted. Radiators and associated ductwork shall comply with the existing F500 bodywork rules.
K. Replacement of the stock camshaft chain tensioner with any other chain tensioner is allowed. The replacement chain tensioner must attach directly to the engine in the original chain tensioner position. There shall be no modifications to the engine to enable the use of the replacement chain tensioner.
L. Replacement of the standard connecting rod fasteners with alternate fasteners is allowed as long as there are no modifications to the production connecting rods. Replacement of other nuts, bolts, fasteners, and washers with common hardware items performing only the same fastening/fitting functions also is permitted as long as there are no modifications to the production parts being assembled or the production assembly.
M. The engine head gasket must be the thickness of the OEM gasket for the year and model of the engine.
N. Camshafts and camshaft drive mechanisms cannot be modified or adjusted in any way unless specifically authorized in these rules.
O. The air inlet system shall have a restrictor placed between the intake manifold and the cylinder head for each cylinder intake port. This restrictor shall be made of .250” thick aluminum plate and shall have a maximum ID of XXX mm. The inlet side of the restrictors may be radiused to a maximum depth of .125”. The CRB may require adjustments to the maximum diameter of the restrictor at any time by publishing the requirements in FasTrack
P. Self-starter: Cars shall be equipped with an on-board self-starter and an on-board power supply controlled by the driver while in a normal driving position.
E.6. Transmission and Final Drive for motorcycle engines
A. Rear wheel drive only is permitted.
B. The final drive ratio is unrestricted. Internal transmission gears shall remain stock.
C. Engines must use the sequentially shifted motorcycle transmission as supplied with the engine. Reverse gear is not required.
D. All gear changes must be initiated and made by the driver. Only mechanical gear shifting mechanisms are allowed. This may include cables, rods, or other mechanical linkage systems. Any other assisted shifting mechanisms are specifically not allowed. This prohibition shall include electric solenoid shifters, air-shifters etc. Other similar devices are NOT permitted. Devices that allow pre-selected gear changes are also prohibited.
E. The clutch assembly is unrestricted except that the clutch engagement system shall be operated solely by driver input and may be mechanical or hydraulic in nature. The driver’s hands or feet must manually operate the clutch and there shall be no operation of the clutch by any assisted method. There shall be no modifications to the engine/transmission to enable the use of replacement clutch components or assemblies.
F. The use of jackshafts to transmit power from the output shaft to the rear axle is allowed.
G. Final drive chain tensioners are allowed.
From the F500 rules:
E.2. Weight and Dimensions
Minimum weight as qualified and raced, with driver, shall be 700 pounds (800 lbs. for AMW and Rotax 494 engines, 825 lbs. for Rotax 493, 835 lbs for 4 stroke 600cc motorcycle engines.
Wheelbase: Maximum 80”
Overall Length: Minimum 110”
Maximum 150”
Overall Width: Minimum 50”
Maximum 55”
F500 since 1984
