Looking for recommended gears for Gingerman for FF with Honda power. Hoosier R60 22.7 diameter.
Formula Ford on Hoosier vintage tires for Blackhawk Farms?
Jack Bartelt
Lola T540 CFF
Looking for gearing for VIR long course with a 10-31 rear axle.
Deleted - no longer needed.
RaceDog
Messenger Racing
Muleshoe, Texas USA
Looking for gearing for Thompson with 10/31 R&P, Kent engine, Formula F Hoosier spec tires.
Curious as to what is the recommended minimum RPM for a Kent Engine?
Typically not much HP below around 4700, motor comes alive around 5200. However, some builds have enough low-end torque to let you pull from a little lower. YMMV.
I've looked, but after sifting through pages of info can't really find anything approaching definitive for a 10:31 Kent at Road America. would greatly appreciate local thoughts for an average/above average Kent; it's a bucket list question. track time would be much better spent learning the track versus working gearing........
Art
artesmith@earthlink.net
Any suggestions, 9:31, CFF, Kent? Thanks!!
Does any one have suggestions for a Club Ford on R60 Hoosier bias ply slicks for NHMS (New Hampshire Motor Speedway) road course?
Final drive 9:31 for me, but I can do the math if only 10:31 suggestions are available.
looking for gearing suggestions for a Thomson, vintage FF, kent, treaded hoosier vintage tires, MK9 box so i believe 8/31 r&p
thanks!
9/31. I’m checking
For reasons I won’t bore you with, one of the two proper race tracks near Sydney is closed. So one of our local clubs is going to hold a championship round at the local drag strip. Any suggestions for gearing for a FF1600, with a 9:31 diff?
For 10/31 and Hoosier FF tires, I've used 17/33, 17/28, 18/25, and 24/28. Those are not optimized for track direction.
This month they are extending the curbing on most corners, using curb profiles and tractive paints that will allow the motorcycles to run on the curbs as part of their race lines. This will change the lines a bit and will increase the straight speeds a little. It will be interesting re-learning the track.
The West-bound line onto the main straight is being extended past the top of the hill. That plus longer curbs on the right prior to the hill may make more difference than we think in straight line speed.
YMMV
Jim Edmonds
Phoenix, AZ
Hi Grahame,
First off, I've never done this. Second, I'm probably just going to say what you were already thinking but wanting confirmation. Nevertheless, opinion follows...
Most of the time is gained from the launch so probably the best gearing would be using lowest 1st gear, hopefully a fixed 1st gear.
Then, assume you'll hit about 100 mph in 4th, which would be 22/29 for my Vintage tire on my March FF at 6800.
Spacing 2nd and 3rd based on my gearing norms gives me this:
14 36 RPM at shift: 17 34 5289 20 32 5440 22 29 5602
"MK9" doesn't necessarily mean an 8:31 by default.
Pretty easy to check without pulling the side cover using the "how far do the tires roll for one rev of the flywheel" method and some simple math with a known gear ratio in the box.
The difference between an 8;31 and 9;31 is 12%, so accuracy doesn't have to be crazy.
Suggestions for Pitt International Raceway please. Thank you.
Umm... what kind of car, what dif ratio would be a good start.
I did this exceice a few years ago
Regards
Etienne
I have an Excel spreadsheet that I likely got from ApexSpeed several years ago that makes the calculations easy for almost any combination. PM with your email address if you want it. You do need to have Excel on your computer to open it. This is what it looks like:
I like this one, also from ApexSpeed some years ago.
Hi all:
2nd try to attach Excel F/F gear spreadsheet (from 2020) to a post...
No joy!
It sez "Invalid file" w/ either an .xls or .xlsx files.
Anyone have a clue?
Regards,
James
Tiga FFA-77 s/n 38
fred short motor racing
"Turning money into noise for over 2/100 of a century"
Back a ways Excel files were known for hiding viruses, so they were banned from this site.
There are currently 12 users browsing this thread. (3 members and 9 guests)
