Welcome- you ask lots of questions
Quote:
Originally Posted by
AlbertaSpeedShop
After reading some of the forum though; will there be a class to enter in a couple years?
I'm about to graduate Automotive Engineering and made a few SAE cars in school. My father had a heart attack last year and its inspired us to work on a car together. For a few reasons something like an F1000 is our target. We're in Canada and F1000 doesn't exist here but Road Atlanta and COTA would be dream weekends and a goal to meet.
I've started a list of "This appears to be within the rules" ideas:
1:Variable Length Intake Runners (controlled by an Arduino if not stock to the motor)
2:What does this 1" from the reference area thing allow? 1" deep tunnels?
3:Can you start the diffuser tunnels early under the 1" thing for more expansion ratio and run less rear wing?
4:It appears you can do those late 80s front wing endplate scoops back to the front wheel centerline? Anything after that would have to be within the 1inchof the reference plane
5: Those fuel pick up papers i think Holley makes em. Is there something like that for Oil possibly making a super thin oil pan possible? (Fuel and oil are hydrocarbons so maybe that paper works for oil?)
6:Fly - By - Wire throttle. ... what extra stipulations does that require can be used for downshift throttle blips?
7:Fly - By - Wire clutch and Anti-Stall. Can't restart on the track but if you never stalled you can get going again.
8:Basalt is allowed in place of CF?
9:Basalt shrouds over control arms making them teardrop shaped and joining the driveshaft and rear LCA into one shape; also tie rod and UCA into one shape
10:Aero shrouding of uprights, brakes. Cover on outside too like from F1 2008 and 09
11:Capacitors in place of Batteries (since theres an Anti-Stall in place)
12: Flex joints for chassis side suspension joints
13: spar for diff structure, rear impact attenuation and rear wing mounts making engine removal quick and easy
14: Is an aluminum monocoque allowed?? I'm not sure what some of the wording is excluding. (9.1.1.2A seems weird to have CF, Kevlar, HONEYCOMB, Fiber Glass eliminating Aluminum monocoque i think) Where can aluminum honeycomb be sandwiched between sheetmetal?
15: i don't see chemical bonding anywhere. Can Side Impact panels be bonded between fasteners for instance?
16: are winglets allowed on uprights? 2G? 3F?
17: Hollow "Blown axles?" 3F?
18: Exhaust Blown Diffuser?
19: Does the car HAVE to be chain driven?
20: I can't see anything about location of fuel cell. Is that unregulated?
21: Does 8D rule out a zeroshift system?
22: is 9D saying wheels should be tethered? Is it talking about the brackets themselves should surround my flex joints? What does it even mean?
23: is Aero open? Is there a chord length or wing area thing in some appendix somewhere i dont see?
24: 9.1.1.10 Brakes are open .... so Adruino controlled brake proportioning valve? (making the most of weight distribution at the start)
Things I can do in Canada:
Hydraulically Interconnected Suspension (did a simple one as my engineering capstone)
Hydralic Inerter (Tungsten mineral oil and coiled tubing over a DAHC)
To answer your first line...of course there will be an F1000 class in 2 years. Don't let all this dooms day crap that a few on this forum are spewing out deter you. The CRB has their panties in a wad over the Gen4 Kawasaki because a few competitors got there asses hand to them...enough said.
1) Nope unless your engine somehow came with these.
2) Basically your tunnels leading up to the diffuser can not rise up more than 1" forward of the rear tire. I'm paraphrasing but that it.
3) You can start it clear up at the leading edge of the floor. Just can't exceed more than 1" rise ahead of the rear tire.
4) Yes as long as it meets the maximum width of front wing.
5) Not sure exactly what you are speaking of but if its what I think no that wouldn't be a good idea.
6) That's a good question. I don't see why not but why would you want to.
7) Again why would you want this? But likely legal.
8) Specifically where would you use this?
9) Technically no you aren't supposed to fair in your suspension arms.
10) YES....you likely didn't see my car at this years Runoffs. I had inner and outer wheel covers they were good for about 3mph and It allowed use to run more wing on the infield.
11) Wow, now you are really reaching out there. I suppose you could.
12) Not likely, the suspension has to be steel...unless your flex joints are steel?
13) If you could somehow make the case they are part of the rear impact structure you bet.
14) Nope...steel tube frame.
15) Nope can only be screwed or riveted at specific minimum intervals.
16) Good question, sort of a kin to Monkey Buckets? Maybe. I had something sort of like this on my car at the Runoffs this year. They came off right away, data didn't support having them on the car.
17) Yes
18) Yes but good luck making it work.
19) Good question
20) GCR pretty specific about this. See basic formula car construction
21) Not sure what zeroshift means
22) Wheels don't have to be tethered
23) As for wings as long as they meet the max width and height your good to go.
24) See GCR for this, it's pretty specific. Calipers are open.
Hydraulic inerter is now outlawed in SCCA.
The Max Grip a tire can give (?)
"There is a point with small bore formula cars that more down force just doesn't increase performance, even in a corner because the car is at the maximum the tires can give."
Steve, I'm trying to fathom this idea. Clearly, there would be a maximum that a tire can give. I suppose that would be the point at which a tire is being used so ferociously that its footprint rubber is no longer flexing, it's simply being shorn away (on the micro level)... and at that point there is no more traction to be had. The tire truly is maxed out.
But is that point anywhere near what the aero down-force on a light formula car could possibly provide to those four tire contact points?
It would seem that even if the aero down-force was many times the weight of the static vehicle, the "maximum the tires can give" point would still be quite some distance away. You'd stupidly fast-heating and fast wearing tires... but the traction would be lavishly increased. At least for a while, until the heat altered all things.
Can you help me on this?
Thanks much,
Chris Crowe
What it's like to drive an F1000
AlbertaSpeedShop
So what's the worst part of driving an FB that it inspires these aerobatic plane analogies? The power to weight maybr means it might be a challenge to put the power down and throttle control is very important.
Is it the physicality of the cars pulling 2G hard on a neck ... again karting and neck strengthening.
As someone who just drove a Formula 1000 car for the first time, I can tell you nothing I've ever driven even came close to preparing me for it. And I've driven the Silver State Classic in a twin-plug 3.5 liter Porsche 930, taken Bondurant's grand prix driving school in Formula Fords, and done autocrosses and time trials starting 36 years ago. Every other car I've driven I felt like I could use full potential pretty quickly; I don't know if I'll ever be able to use the full potential of the F1000. It feels like it literally has no limits; the only limits are those of the driver. This video gives you a taste of what it feels like:
https://www.youtube.com/watch?v=9kufacVXlSc
-Jim
