Tires are one of racings biggest expenses and have a large influence on performance. Also since different tires are needed to be “competitive” at different levels and within various regions we are limiting our entries.
If we had a durable spec tire for FF and CF nationwide and reinstated the tire rule (race what you qualify on) I believe entries would increase.
Here is my reasoning.
1 Hopefully tire budgets would go down freeing up more funds for more races per competitor. Maybe a new set of hard tires will be quicker than a set that has run a few heat cycles but we already have that situation anyway. Hopefully the difference with hard spec tires will be less. Even if it isn't the hard tires should last longer for those that want to run them in more races without being unsafe and they would at least be the same compound as the guy on new tires.
2 I believe most if not all Regional CFs run a hard spec tire already. To enter a National race requires a different set of tires or be at a competitive disadvantage. If they already had the same tire as the competition there would be more incentive to enter their local National.
3 If all FF/CFs nationwide had the same spec tire then there may be more racing at the Regional level as well. Currently MARRS and SARRC use different brands of hard spec tires for their CF series. If you have the wrong brand of hard spec tire a CF is reclassified as a FF regardless of the chassis age/design. With a nationwide spec tire CF cars could cross over to race at other tracks more easily. Retain the chassis rules for CF at the regional level; just require the same tire as FF nationwide. The more cars we get out at any level will just feed the class more.
4 Maybe the tire price would go down if one manufacturer was guaranteed all of the FF/CF business. I know my proposal kills competition between manufacturers but maybevolume, 1 compound of tire (ease of production, same materials, fewer types of tire to stock) and less development cost will result in lower cost.
This should be implemented with enough lead time so that we don’t obsolete the tires already on cars since that could reduce our fields rather than increase them. Let the drivers replace the tires at a natural cycle; don’t force a new purchase right away. Perhaps we should leave rain tires open for a longer period of time (or forever?) since they are replaced less frequently.
Although it would be nice to be able to cross the border and play with our Canadian cousins more readily (and vice versa) I feel there will be less opposition to a spec slick rather than treaded tires since we are comfortable with the slicks and the cars are set up to work on them.
I know there are problems with this idea. Probably more than can be overcome or than I can even imagine. Regional competitors will want to keep the brand they are familiar with. Maybe the regions even have deals worked out with the manufacturers, I don’t know. Dave Gomberg already mentioned there is opposition to reinstating the tire rule. Why it went away I have no idea. The only legitimate reason I can think of was that the ultra soft tires couldn’t make it through the qualifying sessions and the race at the Runoffs safely. A hard spec tire would leave that reason without merit in my opinion.
I don’t think we can do anything that requires engineering changes such as a new motor (if we could ever agree to one) and keep the fields we have now. Mike Sauce’s idea for different weights looked good at first glance but the heaviest cars would be the ones with the lightest minimum weight, they would have to spend money to get down to that weight. The newer cars would have to figure out how to add substantial weight without much room to work with.
If we can just level the playing field some and reduce the cost it would help the class. I don’t see how this would hurt Formula Ford as a whole. I’m sure some individuals will feel otherwise and I welcome their reasons why.
This won’t cost much in the long run. We all need to change tires at some point.
You may start throwing stones.
Mark Walthew
