Results 1 to 23 of 23
    Longmont, CO
    Default Identifying various makes of steel wheels
    Note: I'm taking the liberty of editing this original post to include info we've agreed on through discussion later in the thread.
    How many different steel wheel makes and models have been used on Formula Fords?
    Can you tell them apart? I certainly can't, but perhaps working together we can start building an online identification guide. I'll post some photos and notes below. If you guys can tell anything from the snapshots - or especially if you have other photos/notes - I hope you'll add them below. Thanks!
    1 - Dick Leehr's Lotus 51c
    Diamond Racing Wheels (specifically their lighter spun-rim version.)
    2 - Jeff Snook's Alexis Mk14
    Diamond Racing Wheels (specifically their heavier rolled-rim version.)
    Note that these have a visible weld seam 180 degrees from the stem.
    3 - Howard Freeman's Merlyn Eleven
    Weller Racing wheels
    4 - Bernard Bradpiece's Merlyn 11A
    Bernard said these are "early Weller" wheels, but we think they're actually Dunlops.
    5 - Dave Fairchild's 11A
    Weller Racing wheels.
    6 - Kyle Kaulback's Lotus 61MX
    Ford passenger car wheels (possibly from a Cortina)
    7 - Scott Fairchild's Royale RP3-A
    One more little thing: how many of you run narrower wheels on the front?
    Cushing, ME
    The wheels on Kyle's Lotus look like Lotus Cortina wheels. They could be a copy, but it is the appropriate design. The only way to be sure is to look for the part number on the inside. I have a set and can go get the number in the shop if anybody needs it.
    Senior Member David Clubine's Avatar
    Ontario Canada
    Liked: 160
    The wheel in picture #4 is the original Dunlop wheel, not a weller.
    Ontario
    Default Wheel ID?
    The Leehr Lotus 51 is wearing Diamond Racing Wheels.
    Kyle Kaulback's Lotus 61 is sitting on Ford rims.
    San Diego,Ca
    Liked: 490
    Formula Ford wheels should all be 5 1/2 in width, by rule.
    Roland Johnson
    San Diego, Ca
    Liked: 291
    Default black round thing holders....
    numbers 4 and 6 look "original"
    i recall that "mags" were ok'd around 1974 on
    early "Lotus " wheels had weird "triangular" slots
    most of mine were bent LOL
    Santa Fe, NM
    Liked: 25
    Default Lotus 51 w/Elan Wheels
    There is a nice picture of a Lotus 51 with those wheels, like the ones which were on my '64 Elan, on the Race Car Sales Site:
    http://www.race-cars.com/carsold/lot...50439183ld.htm
    The sold car is very pretty in the iconic Lotus green & yellow. I have wondered whether Roland is correct - did the very earliest FF's all have 5.5 inch wheels on both ends?
    - Frank C
    Edit - Thanks Roland (below). I wasn't sure the Elan wheels were 5.5, and I also wondered whether the wheels identified as Dunlop above were Spitfire.
    San Diego,Ca
    Liked: 490
    The 1969 GCR, the year that FFord was recognized as a class, specifies that the wheels must be steel, of "standard manufacture" (but offset was free), 13in diameter, and a max width of 5 /12 in. I suppose that someone could have used less than 5 1/2 width on the cars. Triumph Spitfire wheels were 4 1/2 in, fit the front hubs of most cars, and were available. We have a set of wheels that came with Vern Jaques Lotus 51. They were 5 1/2 in all the way around, with the two different bolt patterns. The very first F Fords had wet sump oiling, and I don't think they had the crossflow engine either. Both of those items went away before the cars came to the U.S.
    Roland Johnson
    San Diego, Ca
    Banned
    Liked: 1116
    re: Diamond wheels in pic 1 and 2? Diamond does/did make wheels available with either a spun shell or rolled shell. Pic 2 is clearly a rolled shell (weld) while pic 1 may be a spun shell.
    Hope that helps.
    Simi Valley
    Liked: 9
    Any Idea on this wheel. Later rim ?? Did my own short survey at 40th
    Hope the picture attached up not that familiar with this ??
    Liked: 291
    Default wheelz
    Quote Originally Posted by DPLarsen View Post
    a Triumph center
    So.Cal.
    Liked: 29
    ...and the hubcap "nubs" in the spider (wheel center) indicate it would have come from a passenger car with hubcaps. This wheel looks homebuilt with a Trumph spider and an aftermarket outer (rim) and will have welments and welds spider to outer and set to the backspacing that is/was wanted and welded. Typical aftermarket rolled outers have an 11.25'"inside diameter and is common in dimension with British spiders.
    Longmont, CO
    Incidentally... I was curious about wheel weight.
    Diamond's website was helpful. They're claimed weights are as follows:
    spun-rim: 10.5#
    rolled-rim: 15#
    The Weller & Motorsport Events websites don't list weight, so I emailed them.
    Weller: 5.7kg (~12.6#)
    I bet OEM (street car) wheels are a lot heavier.
    Member Dick Leehr's Avatar
    Warwick NY/Londonderry NH
    Default Steel Wheels
    British V8
    Thanks for including my car in your review.
    Now that I have bent one of the wheels beyond repair, I am looking for a pair of the 5.5 inch Diamond spun wheels. All suggestions welcome. I will try Diamond direct but willing to go with a used pair as well.
    Dick Leehr
    So.Cal.
    Liked: 29
    Default Diamond wheels
    Dick..........sent you a pm
    JB
    Longmont, CO
    Now for something a bit different...
    Can one of you please identify these alloy wheels (make and model)?
    Thanks!
    Senior Member gord leach's Avatar
    sask,canada
    I believe American Racing "silverstone"
    later Gord
    BTW...only toilets need doors
    www.blurredvisionracing.com
    Longmont, CO
    This FF board seems quiet until someone asks a question... but then answers come so quick. Thanks Gord!
    Fort Worth, TX
    Default Spun vs Rolled
    Spun vs rolled. Any opinions for formula ford?
    Liked: 291
    Quote Originally Posted by roosta View Post
    obviously the car is better off spun than rolled
  21. The following 2 users liked this post:
  22. #21
    Park City, Utah
    [QUOTE=BritishV8;353779]Now for something a bit different...
  23. #22
    Stayner, Ontario,Canada
    Liked: 24
    Good one
    Dave Coughlin
  24. #23
    CA
    Liked: 246
    That is Andy Antipas Mk6 and they are indeed American Racing "Silverstone's as mentioned above. Todd
