Page 2 of 11 FirstFirst 123456 ... LastLast
Results 41 to 80 of 429
  1. #41
    Senior Member thunderracing91's Avatar
    WI
    Default Memphis
    I am thinking of going to Memphis March 11-12. Anybody have some baseline gearing for memphis motorsports park? I run a 9:31 R&P with hoosiers.
    Thanks!
    Andrew
  2. #42
    Contributing Member Tim Webb's Avatar
    Fayetteville, AR
    Default Hallett Gears
    A buddy of mine will be running his vintage FF at Hallett in a few weeks with CVAR. He needs a good place to start with respect to ratios.
    This is what I have been told:
    9.31 R/P
    17-34, 19-31, 21-29, 21-25
    10.31 R/P
    16-36, 18-33, 20-31, and 22-29.
    Are these ratios close?
  3. #43
    Santa Fe, NM
    Liked: 25
    Yes, at least without checking tire diameters. They are close to what I ran with 22.5 inch diameter tires in CF. I did change, though. I sent you an e-mail.
    - Frank C
  4. #44
    Denver
    Liked: 301
    I've used 18:34, 20:30, 22:29, 23:27 sucessfully (9:31 w/ 22.5" rears)
  5. #45
    Contributing Member Comp89's Avatar
    Ottawa, Ontario. Canada
    Default Gears for Savannah
    What would be the best gears (9/31) for Savannah?
    J-Guy
  6. #46
    Orlando Florida 32812
    Liked: 605
    savannah >>>here's something 20/32 21/30 24/28 25/25
    here's something else...run a taller first than above, just a tooth or two under the second ratio...use it as an alternative second if you're slowed a little by traffic in turns 5-6 ..also get a one tooth under fourth - if the wind is coming strong from the west, run it
  7. #47
    Thanks, it will be usefull...
    J-Guy
  8. #48
    Arlington ,Tx
    We run these gear sets for the following cars at Hallett:
    Merlyn MK 11 9/31 17/35 19/32 21/29 23/28 best lap 1:23.87 Dunlop Mono Tires
    Crossle 16 9/31 17/34 19/32 22/30 23/28 best lap 1:25.48 Dunlop Mono Tires
    Sauce FF 10/31 16/35 18/32 20/31 22/29 best lap 1:18.89 Goodyear 175 c
  9. #49
    Senior Member Ian McKechnie's Avatar
    Rockaway, New Jersey
    Default Shenandoah at Summit Point
    Need FF gearing suggestions for the Shenandoah circuit at Summit Point for a 10:31 final drive ratio. If you do not have it for a 10;31, I can convert if you specify what FDR it is for.
    Ian L. McKechnie
    Ian L. McKechnie (dad)
    Crewchief FC 61
  10. #50
    Default Sears Point
    I'm hoping to go to this track. Any NorCal guys care to share gearing? I have a 10:31 R&P in my Swift but I can easily convert from 9:31 info.
  11. #51
    Greg Mercurio
    Guest
    Start with the gears you run on the long course at Bwillow but one tooth shorter in 4th. You may need to adjust 3rd to get a good pull up the hill into the carousel.
  12. #52
    Senior Member R.DeVoe's Avatar
    Philadelphia, PA
    Awesome thread! I am looking for FF1600 gearing (10:31 R&P) for the following tracks:
    1. Lime Rock Park
    2. Summit Point (I saw numerous requests with no answers)
    3. Pocono (All courses if possible)
    4. VIR
    Any help is better than none. Thanks.
    "The winner ain't the one with the fastest car, it's the one who refuses to lose." - Dale Earnhardt Sr.
  13. #53
    Contributing Member R John Lye's Avatar
    Palmyra, VA
    Default Summit Gears
    Here's a gearing suggestion for Summit (I won't say that this is the
    best, but it is what's currently in my car with a 10:31 CWP):
    1st = 17:33
    2nd = 20:30
    3rd = 22:28
    4th = 24:27
    John
  14. #54
    Philadelphia, PA
    Thanks John, now if only i could get the gearing for Lime Rock Park. I am going to try to make it to the June, July, and August regionals.
  15. #55
    Senior Member Dave SanF 50's Avatar
    Alameda in SF Bay area (CA)
    Liked: 34
    Default Grearing for Sears
    Garey, with my DB1 and a 9:31, I run the following:
    18:33
    21:31
    23:29
    25:27
    dave
    There will be a crowd. 14 CFs and 14 FFs registered. Add in 18 Vees + 1 F5.
    The Vees and F5 have a separate qual and split start.
    dave
  16. #56
    Member jpmacnicholl's Avatar
    bethel,ct
    Default Shenandoah Gearing
    Looking For Starting Point For F/F With 9:31
    Jim MacNicholl
  17. #57
    Contributing Member Jonathan Hirst's Avatar
    Leduc County, Alberta
    Default Gratton Gears
    10:31 CWP
    Club Ford
    Hoosier R60's
    Any suggestions?
    Also - I cannot locate the gearing suggestions on the Taylor website despite a number of people referencing Craigs list. Can someone post a link or are they in his catalogue?
    - Jonathan
    Ferret Industries Archival site
    Ferret Industries on Facebook
    Basement Bookshelf FF/CF Scanned article Archive
  18. #58
    Senior Member racerxlilbro's Avatar
    Woodland Hills, CA
    Default Buttonwillow CW#13?
    Hi all!
    I'm running CF at Buttonwillow later this month. My car has a 9:31 CWP, and we run on American Racers.
    Anyone have a starting point for me?
    Thanks in advance!
    Brad
    Go that way, really fast. If something gets in your way, turn.
  19. #59
    San Diego,Ca
    Liked: 492
    17 / 34, 20 / 31, 23 / 29, 25 / 26
    Roland Johnson
    San Diego, Ca
  20. #60
    Default Gratton - Search Results here
    Found it myself - thanks.
    Gratton Gears Search
    -- Jonathan
  21. #61
    Contributing Member Stan Vann's Avatar
    Murfreesboro, NC
    Default CMP gearing
    I'm just back from driving CMP full course for the first time. I found that for a 1970 Vintage FF1600 with 9/31, that 18/33, 21/31, 23/29, 24/27 worked very well. I'm sure current chassis might need more top end. This setup gives you speeds of about 72, 90, 105, and 118. I got down to 1:48 on year old Hoosiers but feel like 1:46's on fresh tires would be easy.
  22. #62
    Woodland Hills, CA
    Quote Originally Posted by Roland V. Johnson
    Thanks, Roland.
    Is that WITH the bus stop? I'm surprised fourth is as tall as what you'd run at Fontana, or WSIR...
    Brad
  23. #63
    San Diego,Ca
    Liked: 492
    I don't think we are running the bus stop. Fontana is a 25 / 25 top. Gearing really depends on your engine and driving style also. Many of the older engines do not have power on the top end.
    Roland Johnson
    San Diego, Ca
  24. #64
    San Diego,Ca
    Liked: 492
    My bad..........I guess we are running the bus stop now.
    17 / 34, 20 / 32, 22 / 29, 24 / 27. Top could be 24 / 28.
    Roland Johnson
    San Diego, Ca
  25. #65
    Woodland Hills, CA
    Thanks!
  26. #66
    Philadelphia, PA
    Default Pocono Long Course Gearing
    I am going to Pocono's long course on May 13th for the Northern New Jersey Regional. I was wondering if anyone knows the correct gearing or have any tips about the proper gearing. Thanks
  27. #67
    Contributing Member J.D. King's Avatar
    Franklinville, NJ
    Liked: 73
    Pocono, I use 19:31, 21:29, 23:27, 25:25. The same gears as I use at Summit Point, you could probably stand a tooth or two lower on 1st to help get out of Devil's Elbow.
    JD
    Zink Z10
  28. #68
    Philadelphia, PA
    I forgot to mention that i have a 10:31 R&P, sorry.
  29. #69
    Franklinville, NJ
    Liked: 73
    Sorry, I should've mentined 9:31 R&P.
    You can get a gear conversion chart from our good friend Craig Taylor here:
    http://www.taylor-race.com/pdf/GearConversion2.pdf
    JD
    Zink Z10
  30. #70
    Philadelphia, PA
    Awesome conversion chart and thanks for the help, still looking for the Lime Rock Park gearing though.
  31. #71
    Senior Member LolaT440's Avatar
    CT
    Default NHIS Gears??????
    Wondering what the NHIS gears are?
  32. #72
    Orlando FL
    Liked: 18
    Default Latest gearing suggestion for V I R ?
    As the full course has added some stuff in recent years, what is the 'current suggestion' for VIR for a 9-31? Thanks, Alan
  33. #73
    Contributing Member Shep's Avatar
    Rochester, NY
    Default Grattan recheck please
    Hey folks,
    Any chance I could get some confirmation/clarification on the Grattan gears?
    Club Ford, Hoosier R60s, 9:31 R&P
    In the thread Jonathan linked above, Jason Byers suggested 17/34, 19/31, 21/29 & 23/27 for a 10:31 R&P, and that converts approximately to
    18/32, 21/31, 23/28, 25/27 for a 9:31 R&P
    Jake's book suggests 20:32, 22:29, 24:27, 26:26 for a 9:31 which is way off the ratios above (but the ratios Jake suggested for 10:31 - 18:32, 21:30, 23:29, 25:27 - are almost an exact match).
    Any help appreciated. I'm hoping to get the right gears into the box this weekend.
    Erik
  34. #74
    Classifieds Super License andyllc's Avatar
    Columbia, SC
    Liked: 201
    Default Kershaw Gears
    Hey Everyone
    The proper gears for Kershaw (CMP) would be greatly appreciated. We are trying to run our Club Ford there but have no idea what happened to the notes that had the gears on them. We run a 9:31 diff but any gears will do just let me know if you are using a 10:31 or 9:31
    Andy
  35. #75
    Contributing Member Joe911's Avatar
    Gainesville FL
    Default CMP gearing
    [SIZE=1]I have this for Kershaw
    9:31 10:31
    17:33 16:34
    21:31 19:32
    23:29 21:30
    24:26 24:28
    [/SIZE]
  36. #76
    San Diego,Ca
    Liked: 492
    Making a trip north. How about gearing for Seattle and Portland with the new
    Festival turn. Club Ford or Vintage Ford.
    Roland Johnson
    San Diego, Ca
  37. #77
    Santa Fe, NM
    Liked: 25
    Default Heartland Park Topeka - FF
    I am looking for suggestions for FF 10:31 gears for Heartland Park Topeka, as being run this coming weekend in the Run Offs configuration. I presume others may be interested in this information, too.
    - Frank C
  38. #78
    Asheville, NC
    Liked: 115
    Default Lowes Motor Speedway
    Anyone have suggestions for CF gears for Charlotte Motor Speedway? Oh, I forgot. It's Lowe's these days. Well, I'm not as young as I used to be. Can't wait to see if I still need to raise the ride height to cure the bump out of NASCAR 4. Only place we ever raised it. Back in the Paleolithic era. Heck, I even raced there in the last ice age - it snowed at a spring national.
    JG
  39. #79
    CT
    Default Gears for Glen Long Course?
    I plan for the Glen school in Sept. I sent an email to SCCA asking if it was long or short course? Anyone know?
    The "book" only has WG for the short course. What are the long gears 9:31?
  40. #80
    Rochester, NY
    Default Glen long course
    Lola,
    I used 20:31, 22:29, 24:28, 25:26 in my club ford and ran a 2:12-ish (not-so-great) best on the long course. Some will say to run a 1 to 1 gear for the back straight, but my motor couldn't pull it.
    1st for the Toe
    2nd for the Ninety, the Heel and the "off camber", maybe the Inner Loop in traffic, probably the Laces
    3rd for Turn 2, Inner and Outer Loop, maybe Laces if you "get it" (I don't), and Turns 10 and 11.
    I figure if I post this, someone might tell me how I have it all wrong...
    Which event will you be doing there?
    - Erik
    Edit - the ratios above are for a 9:31 R&P
