Results 1 to 15 of 15
    Hellam, Pennsylvania
    Default Need Help- Setting Caster on 80-90’s F1 Type Suspension
    Hey yall, looking for some help here. A good friend of ours has a 1965 Porsche 911 that he had built into a full tube chassis race car with suspension that is based off a 80’s-90’s formula suspension. He owned and raced the car for about 30 years before cutting it up, but that’s not the point of this post. We are having issues trying to set REAR caster on the rear of the car. We are hoping to find someone who has some ideas on how to check and set this. We have a couple ideas, but we’d like to hear other outside suggestions.
    Thank you for any help!
    Port Ludlow WA
    Liked: 116
    Default More pictures
    Can you please post a few pictures of the shock attachment points?
    Thank you
    Paso Robles, CA
    Liked: 307
    I think it's adjusted by changing the lengths of the legs in the lower a-arm. But really that's would only be adjustable by a very small amount.
    I don't think that would be very important since there should be very little toe change with heave motion assuming the upper links are close in length.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Quote Originally Posted by marchsv View Post
    Thank you
    I will! I leave for a two day trip tomorrow and I’ll take more when I get back. Thank you.
    Adjusting is not our current problem- it’s how to measure where we are right now and how much caster it needs to have. Possibly considering setting it close to a newer 911, but trying to figure out an accurate way to check it and see where we are now. Thank you for the response!
    Pittsboro IN
    Liked: 284
    Bump steer guages
    Liked: 1592
    Depending on how accurate it needs to be, Compress the suspension to ride ht using a jack, and then project the axis to the ground using a straight edge and drop a vertical with a plumb bob, and then just do some geometry to get the angle?
    Carroll Smith book Tune to Win have a method?
    New Mexico USA
    Liked: 64
    Default Caster may not be the right characteristic to worry about
    Quote Originally Posted by Rhiggins13 View Post
    Following Carroll Smith's methodology, I would focus on bump steer as the parameter to measure and optimize at the rear of the car. Typically one would try to setup a road racing car with the same bump steer behavior on the right and left sides (at either front or rear). Although Smith mostly wrote about (and worked on, to my knowledge) formula & sports racing cars. I would think that similar principles should apply to a 911.
    For a modest power-to-weight formula car a starting point for rear suspension alignment would be 0 degrees of toe-in change at the rear (through the full range of droop to bump travel). Toe-in at ride height might be set at 0 degrees to 0.5 degrees (or more if typical practice for racing 911s). A full rear-engine car like the 911, typically has a tendency to over-steer (hope this isn't an over-generalization!!). A modest amount of toe-in increase (+ 0.5 to 1 degree, perhaps) on bump at the rear would tend to counter this.
    It will be interesting to hear what approach the original poster decides to follow & what the on-track results are.
    Lee
    New Mexico USA
    Liked: 64
    Default Check out this older ApexSpeed thread for concepts
    Ryan --
    In the last 1/3 (or so) of following (2021) thread on Ackerman there are some comments from Steve Lathrop & Greg Rice about rear-end toe (toe-in versus toe-out) settings relating to handling balance--
    https://www.apexspeed.com/forums/sho...erman-question
    Although they discuss static (that is, @ nominal ride height) rear-end toe settings, try to visualize similar "steering" effects related to the rear outside tire toe change during cornering-roll induced bump.
    Let us know what you try out & results.
    Lee
    near Athens, GA
    Liked: 903
    ..he had built into a full tube chassis race car with suspension that is based off a 80’s-90’s formula suspension
    Seems like a few good suggestions here, but I would think that WHOMEVER actually BUILT (see above snip) this chassis, would have to have had some ideas about just WHERE to put things .. and therefore HOW to set it up. Is he/she NOT still around? Sure seems like that would be the best source to get your answers. Decently 'built' cars (and this one certainly LOOKS well built) aren't just thrown together without a LOT of knowledge... even to get started on something like this would take a MINTFULL of knowledge background.
    Steve, FV80 (knows NOTHING about anything with fenders <VBG>)
    hey Steve, he is still around but absolutely does not want anything to do with race cars. He is retired and over anything involving racing; we tried to reach out to him numerous times and he was not interested. He developed and designed F1 cars in this era. So yes he is still around but is not willing to offer any help.
    We ran the car two weeks ago at New Jersey Motorsports Park (Lightning.) Started the day with a 1:29, eventually ended up getting to a 1:19. We changed the upper toe bar’s position inward, and when the suspension cycles up and down and bump steers towards more toe in, and before it was rolling toe out as the suspension was compressed. We also went up in spring rate and stiffened the rear suspension (800 springs to 1000, could have gone to 1200.) Changed toe in by 1/4° each session, and the car feels much better. Still needs more adjustment. Chatting with Penske this week to talk about shock settings (triple adjustable) and go from there. We did the old small change, drive a session, small change and drive a session.
    Thank you to everyone’s input. Still going to keep working on it, driver and car both need a lot more track time together but ended up with a second and a first overall in ST/GT.
    New Mexico USA
    Liked: 64
    Default Feedback, Yeah!
    hey. So yes he is still around but is not willing to offer any help. [....]
    We changed the upper toe bar’s position inward, and when the suspension cycles up and down and bump steers towards more toe in, and before it was rolling toe out as the suspension was compressed. We also went up in spring rate and stiffened the rear suspension (800 springs to 1000, could have gone to 1200.) Changed toe in by 1/4° each session, and the car feels much better. ... We did the old small change, drive a session, small change and drive a session.....
    Ryan -- It's nice to get some feedback regarding how effective the suggestions provided to the original poster have been on track!
    There may be a point (perhaps now) where it will be valuable to make no mechanical changes between sessions & see if lap time improvements are because of driver improvements. Might be helpful to go one (or several) session(s) in this mode to see if driver performance "plateaus". Then could put in more mechanical changes to pursue more improvement & better know why improvement (or reverse) occurs (driver progress? or, mechanical?).
    Interaction of adjustments to suspension links can be hard to predict. That would warrant trial changes @ home (with careful, detailed notes) to prepare for at-track changes anticipated.
    Quote Originally Posted by Lee Johnson View Post
    We had chatted about this, as well. Issue is the car is still very unstable under braking and somewhat unstable at high speeds. We shoved my dad in the car for two sessions to see how he felt and what his opinion was, and he agreed. The car is improving, but still issues with stability, not driver technique. Dad and I both drive and race similar but different styles.
  17. #14
    near Athens, GA
    Liked: 903
    Unstable @ any speed... I'd suggest adding some toe-in on all corners until you get it 'comfortably stable'. When the driver is 'uneasy ' it's hard to think about adjustments that might make improvements.
    Ymmv
    Steve, fv80
    New Mexico USA
    Liked: 64
    Ryan -- For directional instability in general, Steve Davis' suggestion of more toe-in sounds sensible. Also, a friend found a newly purchased, used formula car with general instability problems had shocks adjusted to max. damping stiffness.
    The "...high speeds.." part of your description may indicate down-force imbalance (I notice a Porsche in the background of your photo that has a rear wing & yours doesn't).
    Does unstable under braking mean directional instability (rear-end tries to precede front)? If so, excessive rear brake bias could be at play. Dave Weitzenhoff in a recent thread posted a link to an older view graph presentation of his own on race car handling. The last of page includes some info on braking issues --
    https://www.apexspeed.com/forums/att...3&d=1539115694
    Lee
