Results 1 to 14 of 14
    Seattle, Washington
    Default Mechanical Brake Switch Install
    I'd like to replace my rain light with a dual rain/brake system. I don't want to tap the brake line for hydraulic actuated switch. What systems have you guys figured out that works well with vintage formula brake pedals?
    Mississauga, Ontario
    Liked: 915
    I may be a bit confused about your post. On my sports racer, all I did was use a simple pressure-activated switch, mounted between the caliper and the brake line banjo fitting. Took 5 mins to install, works just fine. Think I got it from Pegasus....
    best,
    bt
    Seattle, Washington
    Default Girling
    ** Actually I'll need to verify that. Currently up on the storage lift and I can't get to it **
    My vintage Girling Master doesn't use a banjo fitting. I either have to tap the hard line or install a mechanical switch.
    best,
    bt
    Liked: 158
    Default maybe?
    look up "backup alarm switch". Typically a spring wand operating a micro switch.
    Contributing Member Ken Lawrence's Avatar
    Tulsa, OK
    Liked: 54
    Default Brake switch
    My GP Spitfire used a switch like this
    Beck/Arnley Stop Light Switch - 201-1105 from Amazon
    Had a small tab off the pedal in the linkage
    worked fine for years
    Paso Robles, CA
    Liked: 307
    Steven Johnson used a reed (edit -- a mecury switch, closes when tilted) switch on Lola S2's, whenever the car slowed significantly, the switch activated turning on the brake light. You might need a magnet to turn it on for tech.
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
    Liked: 872
    I've never seen a Vintage Formula car (or any formula car) with a brake light so your question is puzzling. Common/required on Sports racers though.
    Port Ludlow WA
    Liked: 116
    Default Brake light
    I believe Sovren requires a brake lights on all cars including FF. Several good options for you to look at.
    Modesto, California
    Quote Originally Posted by scottjk View Post
    The Austin Healey Sprite uses a T fitting on the brake line and a pressure switch available from Moss Motors https://mossmotors.com/542-110-switc...ed-pipe-thread
    $10 or a mechanical switch from e- type Jag is available for $27 from Moss https://mossmotors.com/26-1005-brake...tch-mechanical
    Regards
    Paul
    Liked: 158
    Default yes
    Quote Originally Posted by marchsv View Post
    Brake lights are required. We have not seen the brake plumbing at the master but it could be hard line plumbed using inverted flair. Why change something simple that works?
    Tacoma, WA
    Liked: 330
    Most of us at Sovren run a banjo bolt brake light switch. Easy to add to the rear master cylinder and can be disconnected electrically when you don’t need it. No springs or rods mounted around the pedals..
    https://www.pegasusautoracing.com/pr...asp?RecID=5028
    if you use one of these, use some silicone where the wires come out of the switch as they are easily pulled out..
    use this adapter if you have hardlines.
    https://www.pegasusautoracing.com/pr...asp?RecID=4195
    Flex line is a snap
    scott, talk to Tracy - he has done a lot of work with this group
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    New Mexico USA
    Liked: 64
    Default Steven Johnson (RIP) brake light switch
    Steven Johnson used a reed switch on Lola S2's, whenever the car slowed significantly, the switch activated turning on the brake light. You might need a magnet to turn it on for tech.
    I recall reading that Steven also (actually?) used a mercury switch of the type that activates as it is tilted. One would need to adjust/calibrate the mounting angle so that a desired stopping deceleration rate (say 0.25g's) turns the switch on. Steven's intention was to avoid putting a pressure actuated switch in a brake line. His reasoning was that if not installed in the right orientation, they can retain an air bubble during bleeding & yield a soft brake pedal. A secondary effect would be that getting off the gas in a lowish gear ratio (or going down a steep hill) might turn on the brake light.
    Lee
    Liked: 781
    Quote Originally Posted by Lee Johnson View Post
    This is also my recollection, I think I read it on the old S2000 board when it was active. I don't recall how he activated it in Tech, though.
    San Jose, Ca
    Liked: 110
    I used a small microswitch that has a soft spring lever that just bends after contact with the front side of the brake pedal.
