Results 1 to 5 of 5
    Mesa, AZ
    For Sale Formula Vee Roller for sale
    This is a copy of a Mysterian M2 FV, built during 1997 to SCCA specs.
    1st raced in May 1998, won ICSCC NW regional championship in 2000.
    $3,200 OBO Located in the Phoenix metro area.
    *** Something important I forget to include is that I removed and inspected the fuel cell when i was cleaning the chassis and it still has about 1/2 gallon of race fuel in it and it looks as good and thin as the day I stopped racing back in 2002, no foam deterioration, no fuel gum at all! ***
    This has been sitting for a long time but i recently have gone thru it and cleaned it up and verified that all electrical items are working, including the starter.
    To get it on the track it will need a minimum of an engine, rear shock, girling cylinders re-built, battery, belts webbing, tires.
    I have full bodywork in buck status , ready for mold making, or the bucks could be re-worked to body panels again without a terrible amount of work.
    I have a vast spare parts inventory, including tools, a long box with zero hours on its rebuild, 4 spare wheels with old mounted rains and lots more. If interested I can e-mail the spreadsheet to you.
    Build highlights:
    · Front End
    · Front Beam has custom torsion spring and ¾” sway bar, race prep’ed spindles with offset bushings
    · Front beam offset shock mounting kit
    · Front brake drums with studs
    · Centered steering with quick steer setup
    · Rear End
    · Short box with 1:26 3rd gear, 4.375
    · Zero roll suspension (like the Mysterian) (missing the Fox Shock).
    · Rear brake drums with studs
    · Chrome Moly rear trailing arms
    · Electrical - full wiring diagram included
    · AMB Transponder - hardwired
    · Master switch with ignition switch (have the wiring schematic)
    · 6 volt starter with push button starter switch,
    · VDO gauges for RPM, Oil Temp, Oil Pressure
    · Idiot light for low oil pressure & high oil temperature
    · Rain light with switch
    · Remote battery plug-in connector 50A
    · Dual aircraft temperature gauge for measuring CHT (Head temp) and EGT (Exhaust temp), CHT is switchable between L & R for dual probe setup)
    · Engine
    · Roxanne's Headers SS
    · Roxanne's Collector 4-2-1 SS
    · Cooling ducts, and engine tins
    · No engine
    · Cylinder head temp probes and exhaust probe.
    · Hardware
    · New composite light weight mirrors
    · Fire Safety system
    · No Battery
    · 5 gallon fuel cell with custom aluminum cover
    · Custom seat
    · Sabelt 6 way safety harness - cam style (never used but belting dates have expired)
    · Brake bias adjuster
    · Other
    · 4 – mounted wheels 4J15, old race tires
    · Datasheets and setup sheets included
    Liked: 292
    Default nice
    very
    Mesa, AZ
    Default Spares PICs 1
    Mesa, AZ
    Default Spares PICs2
    Mesa, AZ
    Default Spares PICs3
There are currently 2 users browsing this thread. (1 members and 1 guests)
  1. Bob VanDyke
