*** SOLD ***
I bought these for a project but didn’t use them.
Was told they are from a Vector with an LD200.
Seens like a good quality piece.
$70 plus shipping.
*** SOLD ***
$70 plus shipping.
The “longer throw” arm has a 5/16” hole. The gap rod end/shock eye clearance is .75”
The shorter throw arm has two .375” holes to choose from, and the gap is .5”
Russ, how thick are the rockers? I assume the bells that go through the rockers just screw into the aluminum bracket? What are the bolt hole dimensions from the rocker center?
Those look like they are a pretty low motion-ratio (MR) setup. You should do an analysis of the total setup you plan to use these with to determine if the MR suits your situation before buying.
Please see next post with picture and measurements.
Oops. Better picture:
A --> B = 4"
A --> C = 2.25"
A --> D = 2.75"
A --> E = 2.5"
Thanks Russ. What I'm really looking for is the design details of how the rockers pivot on the post. I don't have a narrow enough chassis to add the entire mount to. My chassis is much wider so this would have to be fairly high up to afford clearance for pushrods.
If you'd like I could ship it to you for evaluation.
Or, send me a PM with your email address and we can discuss options.
Maybe you could cut it in half and refabricate it with the width (and different angles) you need for your design.
Bump.
Will sell for $20 plus shipping.
Sold.
Thank you.
