For sale is a 1989 EuroSwift SE-1 with a Ford Kent engine and all original logbooks, an absolute gem for car enthusiasts and collectors alike, as well as new beginners looking for seat time like I was. With low mileage in comparison to other cars of its vintage era, the car wasn’t assembled and raced until 1996. This EuroSwift SE-1 stands out as a truly rare find. If you’ve been searching for a vintage FF that combines style, performance, and reliability, this is the perfect choice.
This car won several SCCA OVR events at Mid-Ohio, Gingerman, and Waterford Hills. Finished 2nd at the Super Tour event at PIRC in 2020 and third at the Mid-Ohio Super Tour event. This car also won the Majors Tour event at Mid-Ohio in 2021. The car has been updated with new electronics, EVO4S Data system with aim dash and GPS, lambda and O2 Sensors, and smarty cam, and all data from the tracks ran at since 2020. All of the engine components including the block and carburetor were purchased new from Ivey Engines, SCAT crank, and rods, and put together by a local engine builder in June 2020. The engine has about 25 hours of run time. The valves were reground at 20 hours. Also has a Hewland LD200 gearbox.
As a bonus, this incredible deal includes a very extensive collection of spare parts which is listed below.
List of spare parts:
Extra Bell Housing
Transponder (wired into the car)
Every essential suspension part to create four extra corners, including uprights with bearings and hubs. Many new pieces were made by GMT Racing with Pat Prince Jigs.
Several Tie Rods (New)
Large plug-in cord for starting the car with the battery
One set of trailer wheels
Formula car jack with jack stands
Three sets of Panasport wheels (2 gray sets, 1 gold set) including one new set of Hoosier slicks
10 extra sets of gears, dog rings, nuts, spacers, cotter pins, snap rings, and shockproof oil.
skid plates
Lower left rear body panel (new)
four full sets of new Hawk blue compound brake pads (New in the box)
Two carbs, one Farley Carb
Starter (New in box)
Airtex Fuel Pump (New in box)
Several rolls of exhaust header wrapping
Original vintage gauges and dash
02 sensor
Petronix Ignitor (New in box)
Bosch coil spark plug wires, distributor gears, distributor cap (Used)
Two Motorola Radios with chargers, one headset, and an extra boomstick
Custom-made car cover
4 CV Joints (Honed by Two dogs racing)
One Driveshaft
Two clutch discs (one new in the box, one used)
Clutch slave (New)
Three Master Cylinders (New)
Aluminum alignment tools
Used brass radiator
Extra front and rear sway bars
Original Nose mold
Original Roll Hoop mold
Nose holder for trailer
Fittings
Valve Springs
Four Wheel spacers (New)
Thirteen GMB wheel bearings (New in box)
Six pack of Canton oil filters (New)
One spare intake manifold
One used Kent engine block, spare connecting rods, crankshaft, and other parts.
Four brake rotors (Used)
One complete engine gasket set (New)
Four wheel hubs (New)
Three Radiator caps (New)
Spare brake lines and fittings (New)
Organizer box with many Heim joints, rocker pivots, spacers and bearings, tie rod mounts, spacer washers, lug nuts, and miscellaneous jam nuts (All New)
Special tool for cylinder head bolts
Organized box containing lots of hardware, nuts, studs, washers, spacers, fittings (Most new)
Organized box containing new tie rods loaded with heim joints, rack and pinion mounts, tie rod mounts, ****4 new shear tabs for front rockers****
Organized box containing starter shims, front axle bolts, many new heim joints, starter solenoid contact kits, brake pedal parts, 20 new rocker pivot bearings, rear lower wishbone bolts, many specialized suspension bolts, jet nuts
Organized box containing 6 new wheel bearings( some of them honed), used drive plates, many specialized bolts, and a container full of fiberglass body assembly parts.
Jake Lamont's Formula Ford book and Hewland manual
Lots of various-size snap rings
Many bottles of oils and fluids needed for the engine, transmission, and brakes (New)
Aluminum firewall
Two large boxes of aluminum pieces
Two large boxes of miscellaneous engine parts
One box of miscellaneous engine gaskets
Along with plenty more miscellaneous parts.
***$35,000 OBO for the car plus all spares*** Car is located in Bethel, Ohio
If interested, call or text 513-330-3331 or email thomasschrageracing@gmail.com and I can send photos of everything.
