Possibly The Best And Most Compete Race Proven Lazer MK2.5 available in the country.....
This car has set numerous track records at Phoenix International Raceway, Firebird International Raceway (Wild Horse Pass), Las Vegas Road Course and Pikes Peak International Raceway. Many majors wins when it was companied. Possibly the finest and most sorted out Lazer manufactured by Campbell Motorsports. Chassis is arrow straight and has never in an accident or bent including the beam and axles. Body work fits as it did when new. All body panels clean with no stress cracks, including all cooling ductwork, head covers and air intakes. Professionally Built 4 piece Nose Mold capable of pulling or manufacturing at least 100+ noses. All grade 8 fine thread bolds with Nylock locking nuts. This car was originally built with all top grade components with no acceptation to cost or quality.
Roller Bearing Front Beam with Sipos Off Set Delrin Bushings, Super tight and amazingly free moving with no binding. All Log Books included noting every race and showing this car had never been bent or wrecked. Not even a minor incident or bent wheel. Original Homologation Papers included. The car was well known in the Southern Pacific Region and had received numerous compliments on how well it was built and the attention to detail given during the build. I really don't want to sell it but I am moving up to Formula F and can't see the car just sitting and not being used. It is a highly competitive car and will be running up front with the right driver.
Fresh National Vee Tech Engine
National Level Carburetor
High Flowing National Level Intake
Lybarger Powder Coated Low Friction Short Box With Polished Gears
Spare Lybarger Long Box With Minimal Hours Usage
Al Verison (Speed Sport) Tri-Y Dyno'd Exhaust System
Fox Front Shocks Dyno'd By Chris Harrison with internal droop limiters
Dual Adjustable Fox Rear Shock with External adjustable Reservoir W-150lb 2.25" spring
Tilton Master Brake and Clutch Cylinders
Tilton Brake Bias Control
Steering Box Knee Protector With Fiberglass Mold
Frontal Intrusion Foot Box Protector
Body Sides Have 6 Layer's of Kevlar For Side Intrusion Protection
Notched Shift Linkage for Extra Interior Space
Remote Air Fuel Mixture LED Gauge with O2 Sensor
All Stainless Braided Aero Quip Lines With Protective Covering / Brake, Clutch, Fuel
All Heim Joints and Rod Ends are Aurora Aero PTFE Lined
Custom Lexan Dash
High Pitch Pizo Low Oil Pressure Alarm
Manual 5Lb Fire Suppression System
Professional 4 Piece Fiberglass Nose Mold
Wired For In Car Radio With Antenna Bracket, Push To Talk, Comes With Radios and Headset
I am selling everything I have that is associated with Formula Vee...
Six Sets of Straight Powder Coated Rockwell Wheels
Five Front Sway Bars
Spare Rear Axles
Spare Powder Coated Backing Plates
Spare Powered Coated Roller Bearing Front Beam
New Rear Control Arm
All Alignment and Set Up Tools
Spare Starters and Parts
New Tilton Master Cylinder
Tilton Master Cylinder Rebuild Kits.
Spare Carburetor
New Tie Rods
Carburetor Jet Kit with Reamers
Wheel Weights and Balancer
New Slave Cylinder and Rebuild Kits
Spare Drums Front and Rear......
Way Too Much Too list. Anything having to do with Formula Vee will go with the car
Please review the pictures but they don't do this car justice...Please contact me for more info or pictures
Asking $12000.00
My E-Mail is
rwallschlaeger@cox.net
Thank You
