Does anyone have a part number for the Pilot bushing for a Formula Ford? probably brass
Thanks in advance.
Allen
Thanks in advance.
Allen
Here is the Pegasus Racing URL for the part (it is a needle bearing, not bronze!) --
https://www.pegasusautoracing.com/pr...asp?RecID=3478
INA # is F331262
OD 21mm
ID 15mm (nominal, actual 15.07mm)
Depth 15mm
thanks, I was hoping for a brass one I need it a little longer
I just measured a brand new Pegasus one ==> 21 mm OD x 16 mm Long (nominal dimensions).
I also wonder what the benefit of a brass (bronze?) one would be? If some dimension might need to be machined to fit, you might consider starting from oil-embedded sleeve bearings. All kinds shown @:
https://www.mcmaster.com/products/bu...ain-bearings~/
Lee
