For Sale: Sadev SL75 six-speed sequential gearbox from Tatuus USF-17. Gearbox is not complete and will require final assembly. New casings front and rear. Used input shaft, shift barrel, diff carrier and cross shaft assembly, spider gears, used ring and
pinion and housing, and bearings 1x shift fork, dog ring input shaft bearing and seal/ front tank cover, shuttle bar and pivot and 4 gear ratios.
Paid $6700.
For Comparison the New Front Casing is $3222, New Rear casing is$2433
$5800 for all in attached pictures.
