Results 1 to 11 of 11
    Houston, Alabama
    Default Axcel Sports Racing Gear
    Bought a FV and will be attending school in Texas in January. I need to get all of my gear in order. These guys popped up somewhere, whats the catch, junk? Suits are like $250.
    https://www.axcelsports.com/sfi-suits-accessories
    Sacramento, California
    Liked: 100
    250 is a base level single layer suit. Price triples by the time you get to a 3 layer.
    Houston, Alabama
    Gotcha, still learning, thanks. $542 when you change to three layer.
    Gulf Breeze
    Liked: 23
    Check out Summitracing.com, they have decent multi layer suits for about $250 or less.
    Member DannyPip's Avatar
    Wallkill NY
    Liked: 38
    I ended up buying a package from Speedway Motors, summer of 2022.
    It was a suit, gloves, and shoes for $350 or so, Zamp brand. I also bought the Zamp brand head and neck restraint, which is adjustable for neck angle. Very important to get it right for you and your car.
    The Speedway nomex socks are horrible, so I bought nicer ones.
    Don't forget your helmet and head sock too. For the helmet I went to a local speed shop(I live near Behrents) and tried them on. That was a good call.
    Last thing you'll need is arm restraints. Make sure they're easy to attach to your car's belts.
    Suit combo:
    https://www.speedwaymotors.com/Zamp-...ey,401809.html
    Hans type device:
    https://www.speedwaymotors.com/Zamp-...it,487156.html
    If you budget $1000 for your gear, you're probably safe.
    alabama
    Liked: 175
    Quote Originally Posted by DannyPip View Post
    Suit combo:
    Hans type device:
    X2 for Speedway. Look at their clearance section. I bought 3 layer sparco for $ 75 last winter older designs but good suit.
    Same for all other gear except helmets.
    BLS
    Houston, Alabama
    Suit combo:
    Hans type device:
    Good info thanks. Its awesome how the prices on head restraint devices have come down. I raced tunnel boats for years and we had 5 point restraints. I believe the device back then was north of $1000. Does SCCA mandate head restraints?
    Wallkill NY
    Liked: 38
    Yes, head and neck restraints are required for SCCA road racing. For a Vee I'd recommend a 6 point formula car harness. Most harnesses today are designed to be used for a Hans, but make sure.
    I have to say I'm really pleased with my safety equipment. I spun almost 180 degrees in a slow corner and was hit in the front beam at about a 45 degree angle at about 40 mph. Afterward, I had ZERO after effects. No aches, pains, nothing at all.
    Make sure you and your car fit and fit well. Take the time and money to do a foam seat. Make sure the belts are TIGHT. That way you don't get hurt.
    Houston, Alabama
    Heck yeah, I have flipped a boat at close to 90 and sunk to the bottom. Terrifying waiting on divers while you breath from an air bottle but all of that gear saved my life. Some of they guys I raced with wouldnt have air onboard with them, felt it was too restrictive when they tried to get out. What if you are unconsious, mind boggling the logic on that.
    Take care - walt
    Liked: 879
    If you're small, I might be able to help with a suit!
    NC
    Liked: 325
    Used suits are available. Check here in the classifieds and ebay among others.
