Originally Posted by
brian styczynski
I think the biggest weight loss you can easily, cheaply get is with the battery. I saved 7.5 lbs with a Shorai, you might get another .5 - 1 lbs with yours. You will get another 4-5 lbs with the starter, ??(I weighed the Imi 105 at 8lbs 13.7 oz, I don't have a stock starter to weigh)?? but the other advantage is that they are indexable so can fit different exhaust configurations and that they don't need a bushing in the trans case.
After that, the next cheap, easy (maybe) thing to do would be trimming your self down 5 or 10 lbs. That could add up to 20 lbs between car and driver this winter. Going after more weight reduction is going to take creativity, more time or money to get diminishing results. That said, ounces add up to pounds eventually.
