Results 1 to 31 of 31
Thread: Clutch Woes
    Senior Member Rene Gimenez's Avatar
    Valencia, California
    Liked: 47
    Default Clutch Woes
    Happy New Year to All!
    This is my set up:
    Van Diemen RF83 FF1600
    Tilton F3 clutch
    External slave
    AN-3 braided line
    This is my problem- after bleeding the line and making sure the it is bubble-free, the clutch goes back to the floor within a minute. When I re-bleed, there is no air in the system. After it goes to the floor it takes me several pumps to get a firm pedal. No leaking or weeping anywhere.
    I have done the following:
    -Rebuilt the Girling master cylinder
    -Change out the Girling for the Wildwood clone
    -Replace the slave cylinder
    All of the connections are tight. Did I miss something?? Yes, I am at about my wit's end.
    Thanks for looking and providing any advice!
    Rene Gimenez
    Liked: 3787
    #1. Is there a point in the system where the line loops up higher than the slave? If so, you may have an air bubble in that loop that is hard to bleed out.
    #2. suspect the master cylinder.
  3. The following 4 users liked this post:
    Tacoma, WA
    Liked: 324
    Check that the pushrod is fully extended. I once had an issue where I ‘thought’ it had the correct clearance, but pushing up on the pushrod moved the piston….
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Liked: 47
    The clutch line is routed up from the master into the upper left frame rail and the out of the frame rail slightly down to the slave. Should I remove the slave cylinder from its bracket and hold it at a point where it would be above the clutch line and bleed it that way?
    John - Double checked that the pushrod is snug to the piston
    Quote Originally Posted by Rene Gimenez View Post
    .... Should I remove the slave cylinder from its bracket and hold it at a point where it would be above the clutch line and bleed it that way?...
    That's what I had to do when I rebuilt all the hydraulics in my March. I put a 1/4 drive socket in place of the rod, then held it in place when a big C-Clamp and bled.
    colorado
    Liked: 162
    It may help to raise the rear of the car as well.
    Liked: 3322
    Quote Originally Posted by bob darcey View Post
    That's what I think will help - you're trying to evacuate air, and it's obviously lighter than brake fluid, so raising the rear helps the air go out the bleeder in the rear.
    Also, any type of pressure or vacuum bleeder will help - a continuous flow of fluid is MUCH more likely to flush air out of high air-trapping spots than non-continuous pedal pumping.
    If that sort of bleeder is not available, increasing your fluid flow velocity by more rapid & frequent pumping may help. You're trying to keep the flow going so the air doesn't have time to return to the high spot(s) between strokes.
    Liked: 1403
    When you rebuilt the cylinders, what type of lubricant did you use on the seals?
    Whit the improper lubricant, I have had problems with the air getting into the system as the cylinders retract in use.
    new zealand
    Liked: 110
    Sounds like a MC issue. Take the line off the MC and block the outlet with a bleed nipple or a bolt with a copper washer (do this with the pedal depressed a little bit; It will save you losing lots of fluid). Bleed if necessary.
    See what happens. The pedal should be a rock and stay that way even with a minute of pushing hard on it (and stay that way if you wait 5 minutes and push again)
    Report back to the family.
    Danbury, CT.
    Liked: 1907
    Get one of these. Drill, tap and install it in the very top of the slave pointing straight up and bleed the system from there from now on.
    Every FF in my shop including mine has this.
    Danbury, CT.
    Liked: 1907
    No, you don't need to do this. Your line is routed the same place as mine and every other RF81-83 that came from VanDiemen.
    The new "Girling" slaves suck. I've had the same issue as you are having numerous times with new slaves. I automatically do what I described above as soon as I pull one out of the box.
  17. #12
    Liked: 47
    Thank you for all of the responses! Now I've got a direction on how to deal with this.
    Since it's the easiest thing to do I'll raise the rear of the car first. If that doesn't work I'll isolate the master cylinder by plugging it off and checking for pressure. Either way I'll also order the NPT brake bleeder/speed bleeder assembly from Pegasus.
    Will post an update as I make (or not make) progress..
  18. #13
    Liked: 47
    Default Update... Success?
    Hi Again-
    Over the past several days I did the following-
    First I capped the AN3 braided line going into the slave cylinder to test the master cylinder. Pedal was very firm, so neither the Master or the AN line seemed to be a problem.
    Next I removed the slave cylinder and took apart the plunger shaft assembly. Made sure that the plunger inside the slave cylinder was as far up the slave cylinder as it would go. Reassembled everything and made sure that the plunger shaft was snug with both the slave cylinder and the clutch arm and not fouling the return spring.
    Raised the rear of the car and bled (have not received the speed bleeder yet).
    The result- I have a very light pedal, and the the clutch arm moves about 1/4 inch consistently. I did check to make sure that there was no play in the clutch arm. This is with a .70 master and a brand new F3 Tilton clutch.
    My concerns are these- the clutch pedal is extremely light and is 1/4 enough movement? Many thanks for your input.
  19. #14
    Derbyshire, United Kingdom
    Liked: 322
    What bore size is your slave cylinder?
  20. #15
    Winter Garden, Florida
    Liked: 160
    I always use a 3/4 master for the clutch.
    Joe
  21. #16
    Danbury, CT.
    Liked: 1907
    Hi Again-
    The new bleeder location will fix your problem.
  22. #17
    Denver
    Liked: 301
    if "No play in the clutch arm" means what it says, the system will be riding the clutch, i.e. riding the throw out bearing and more importantly the crankshaft's thrust washers. All very bad. The clutch arm should have a tiny bit of free play before engaging the bobbin to the pressure plate fingers. Not a lot, but NOT constantly touching. Maybe 1/16+" free-play at the bobbin, which might translate to 1/4" free movement of clutch arm. Burning up a crank's thrust washer because of a too-tight system will not be a happy outcome. Ask me how I know. My issue was a faulty hydraulic slave not retreating and thus "riding" the clutch and burning up a crank thrust washer. But hydraulic or mechanical lack of free play would be the same outcome.
  24. #18
    Prescott, AZ
    Liked: 182
    I had a similar problem with a troublesome car. New Wilwood MCs. Bleed many times and many ways. Would not consistently keep a good pedal. Replaced the defective MC and problems solved.
    The valve for fluid fill and return was defective. Thanks Chris Harrison!
    Returned the offending new MC to Wilwood who said it was fine but they sent a new MC as a goodwill gesture .
    You might consider buying/ borrowing a new or known functional quality MC.
  25. #19
    Albuquerque, NM
    Default Check the master free play
    Make sure that you have a little free play in the master cylinder push rod when the pedal is released. The piston in the master cylinder has to be able to return all the way and if there's no play in the push rod that can't happen.
  26. #20
    Danbury, CT.
    Liked: 1907
    So.......what was the conclusion to this?
  28. #21
    San Diego,Ca
    Liked: 492
    Default Clutch
    I am pretty sure he is installing an annular unit. I have run across a lot of worn out clutch release cross shafts and bushings and bent levers in the last few years. With the F-3 style clutches they and your clutch leg take a pounding.
    Roland Johnson
    San Diego, Ca
  30. #22
    colorado
    Liked: 162
    My first Tilton F3 clutch came with an "orange" diaphragm spring, and it was a bear to disengage. Had it chnged to a "buff" spring and it made a huge difference--the "buff" spring is more than adequate for a 1600 FF.
  32. #23
    Denver
    Liked: 301
    Hi Again-
    . . . and made sure that the plunger shaft was snug with both the slave cylinder and the clutch arm . . . ..
    Make sure there is a LITTTLE play at the clutch arm. See my previous comment. You do NOT want the bobbin constantly in touch with the fingers.
  33. #24
    Mooresville, NC
    Just buy new Slave & Master Cylinders every year.
    This expenditure is a Drop in the Bucket compaired to the time you will waste chasing a problem.
  34. #25
    Liked: 3322
    Default Hmmmmm...
    IMO, unless you have money to burn, that's an unnecessary expense. My master cylinders last for many (>10) years. If they were a "replace every year" item, I'd do it, but I've never had an issue related to master cylinders. I do rebuild the clutch slave every year, and the calipers if the seals get too loose or there's some other issue, but I don't replace them.
    Quote Originally Posted by Sean Gallagher View Post
    This expenditure is a Drop in the Bucket compared to the time you will waste chasing a problem.
  35. The following 3 users liked this post:
  36. #26
    NW Colorado
    Liked: 30
    Default Ever wonder...
    ...what the inside of a Girling slave cylinder looks like?
    The two holes, one is the feed from the master and the other is for the bleed. 3cc of dead airspace up there.
    John Mihalich, Jr.
    Lotus 61/FF/28
  38. #27
    Danbury, CT.
    Liked: 1907
    Quote Originally Posted by LFFR View Post
    John Mihalich, Jr.
    Lotus 61/FF/28
    And that is why a bleeder tapped into the top of a slave cylinder that was originally designed to sit sideways fixes your soft clutch pedal problems.
    Ever wonder why there's left and right hand slave cylinders?
    To put the bleeder on top depending on which side of a gearbox it's mounted on.
    This slave was never designed to be mounted straight up and down. It was originally designed to be mounted sideways.
  39. The following 7 users liked this post:
  40. #28
    West Union, IL USA
    Liked: 319
    Default thank you
    for enlightening me with the cutaway. I had no idea there was that much dead space in there!
    I will be pulling mine off, drilling, tapping, etc.
    So really, if you drill and tap the top you can just plug the side opposite the input, right?
    Thanks!
  41. #29
    Danbury, CT.
    Liked: 1907
    Thanks!
    Yes
  42. #30
    Member Domiteaux's Avatar
    Dallas, Texas
    Default Girling Slave cylinder cutaway. No wonder
    Yes
    Wow, now it makes sense why its always a soft pedal, after 50 years of FF racing with these sleve cylinders suprised no one sell a properly designed version, Hint ( Willwood ) . So machine a basic fitting and adapter with a remote bleeder?
  43. #31
    Liked: 955
    The reason the supply and bleed holes are in that position was due to its original horizontal vs vertical installation position. Remove the slave from it's position, zip tie or hose clamp the piston so it doesn't leave the cylinder under a little pressure, turn it so the bleed screw is at the highest point and bleed again.
