Vandervell VPR 819 .25mm connecting rod bearings C405 new (1) set $40
Vandervell VPR 91350 .25mm Crank bearings C401 new (1) set $50
Glacier C3037S Std camshaft bearings new (1) set $25
Vandervell thrust bearings new VPW8 (1) set $12
Cam followers marked 470, 13.0mm for uprated Kent new (2) sets available $100 each
Cam followers marked 450, 11.0mm for original kent new (1) set $100
Mr. Gasket Bell Crank Kit new $30
New non-standard water neck (see pics) $50
Used stock water neck (2) available $25 each
34 tooth water pump pulley, .625 diameter shaft used (1) $50
Titan dry sump pump shaft and pressure rotor assembly (2) available $100 each - SOLD
Kent Water Pump Belt, 180XL050, 90 Teeth, 1/2 in Wide $5
Kent Water Pump Belt, 170XL050, 85 Teeth, 1/2 in Wide $5
Plus shipping.
