Results 1 to 5 of 5
    Peninsula, Ohio
    Liked: 108
    Default Rt4 cockpit size
    What is maximum driver size for a RT4? I'm 6' 190 not very wide at the shoulders.
    5thanks
    Liked: 555
    Quote Originally Posted by djones View Post
    I think you'll fit. I'm 6', 175 lb and I'm fairly comfortable in my '83 RT4. More hip room than my old Swift DB4. The only restrictions I feel in the RT4 are around the elbow area, but once on track I forget all about it. :-)
    on edit: My RT4 has forward facing roll hoop braces bent outward (by a previous owner). That might be a reason why my car feels roomy enough for me.
    Santa Rosa, CA
    Liked: 268
    Default Rt4
    You would have no problem in a RT4 from a fitting size. Fairly large cockpit and if you don't have really wide shoulders plenty of room even with forward facing roll bars.
    Peninsula, Ohio
    Liked: 108
    Default Rt4/5
    Thanks guys. Turns out the car in question is a RT5. Assuming cockpit size is similar. Going out to look at it in a couple weeks and will find out for sure.
    Don
    Liked: 555
    Don
    I'm pretty sure they are the same.
    I recently measured the width at the bottom bottom of my RT4 at the narrowest part of the tub at the seat/floor. It was about 15".
    The lap belts' attachments (on my car - maybe the same for all RT4's) makes the width about 14" there.
    At the rearmost of the seat/floor, it's about 16" wide.
    BTW, I think the most interesting difference between the RT4 and RT5 is the fuel cell size. The RT4's is bigger (taller behind the driver). I assume this was for the longer distances of the pro Formula Atlantic (and F2) races compared to FSV/F3.
