Hi everyone,
I've decided to sell my RF97 after racing it for a few years with the GLC. Car was last raced at Mid-Ohio in July 2021 (a month ago). I'll get more photos posted soon, but I wanted to get this post out there.
I originally bought the car in 2019 and raced with the GLC (Keith Averill’s group). I'd like to sell everything as a package. I’ll include as much with the car as I can, even leftover fluids, oil, etc. I have from running the car. Pretty much everything you would need to go road racing, except safety gear (although I’ve got some stuff for sale too). This would be a great car for someone looking to get into racing formula cars. NEED TO SELL BY THE END OF SEPTEMBER!
The car:
- Painted in Ford Grabber Blue by previous owner
- Rebuilt PINTO engine with ~4 hrs of race time
- Complete teardown, new bearings, rings, block honed, crankshaft magnafluxed and polished
- Ivey prepped head with updated cam
- Brand-new Ivey prepped carb
- Crower short rods with Ivey/CP pistons (reused with Line2line piston coating)
- TDC rebuilt oil pump with updated pressure section
- Hitech headers/exhaust
- New ignition coil, spark plug wires, fuel pump
- Engine dyno'd at 130 hp peak at a local drag racer's shop. 'Low' number most likely due to dyno-to-dyno variation (this dyno is regularly used for engines with >1000hp). The car is definitely not lacking in straight-line speed.
- Car was previously run by Comprent, includes old setup sheets and running notes
- Includes logbooks
- Includes wireless AMB transponder (non-subscription version)
- Penske 8760 3-way adjustable dampers, Hyperco springs
- Wiring harness redone over the winter
- New Spa oil pressure/temperature dual gauge, Sniper shift light
- AIM Solo 2 mounted to steering wheel for lap times, basic telemetry
- 3 sets of 5-spoke OZ mag wheels with tires mounted:
- Spec R60A tires with ~3HC
- Spec rains (brand-new, unused)
- Takeoff practice R35B tires
- 22 gear sets
- New 5.5” Tilton clutch with Tilton throwout bearing and factory rebuilt pressure plate (by HRP)
- Resurfaced flywheel
- Fuel cell in good condition (checked over winter), manufactured in 2011 per certificate from ATL
- Willans belts good through 2022
- Custom bead seat
- Apex joints on most shift linkage joints
- KFP red brake pads
- LD20 calipers on all four corners
- A disclaimer: I tagged someone (sorry Tim!) at Mid-Ohio and crunched the nose and dented the LH front wing main element. Got a new nose from Primus but still needs to be painted. Paint is coming this week. Wing is usable, haven’t replaced it.
Tools
- Alignment jig (bolts to chassis)
- LD200 dummy shaft for gear changes
- Watkins Smart Camber Gauge
- Starter battery (Optima yellowtop)
- Longacre Pyrometer
- High stands
- Foldable low stands
- Quick jack
- Air tank
- Pop-up canopy
- Cot (for sleeping in the trailer)
- Fuel jugs
- Engine legs with casters (for shipping or rolling around engine)
- Extensive documentation (gear chart, setup/running notes, wiring diagram, engine rebuild documentation, parts list, etc.)
Spares
- Spare engine block (came from running FC)
- Spare good head (should be rebuild, came from running FC)
- Crush box
- Extra set of R35 takeoffs for practice tires
- Spare rear wing assembly (basically brand-new)
- RR lower control arm
- Front upper control arm
- Rear upper control arm
- Pushrods, tie rods, toe links
- Axle
- Lead ballast
- LD20 caliper seals (2 sets)
- Springs (400 lbs/in, 650 lbs/in)
- Ignition parts (plugs, condenser, coil, points, rotors, distributor, plug wires)
- Carb jets
- Misc. engine parts
- Misc. plumbing, AN fittings, etc.
- Spare battery
- Cockpit front-bar adjuster (removed from car but easy to put back)
Trailer
- Perfect for a formula car, can easily be towed by a light-duty pickup truck
- 2016 Interstate 7’ x 18’ v-nose enclosed trailer (dual axle)
- 6.7’ x 17.6’ interior box dimensions
- E-track with over-tire straps to tie down car
- Rubber diamond-plate floor
- Winch installed in floor
- Tire rack
- Electric tongue jack (manual tongue jack included)
- Aluminum wheels
- Spare tire
- Dent in front part of roof from a tree falling on the trailer (just cosmetic, trailer is watertight, etc.)
- One tire has a very slow leak but should be checked/filled before towing.
Price for everything above (car + spares + trailer) - $18000
Price for car + spares (no trailer) - $15000
More photos and documentation here:
https://drive.google.com/drive/folde...ym?usp=sharing
